its totally different than the stock rom . other animations (mix jelly bean and ios)
changed default settings
because i cannot test everything , must you test this rom and let me now what works or not.
just for sure make a cwm backup off your current finless rom .
its not a brick rom i flashed this on my 10b G3 and it's booted fine.
what's in this rom works for the 10bG3
what's cooked in this rom.
flash player 11.1 (works with dolphin and opera not opera mini. on 10b G3)
google play
superuser
init.rc modded with v6 supercharger
services.jar replaced with modded on for v6 supercharger.
different build.prop tweaks
init.d added too the rom.
quickpic instead of gallery.
adaway for a adfree tablet.
awesome beats audio
speaker boost (just be careful you don't set too high for your speaker)
camera ics instead off default camera.
what's removed
gmail,musicplayer,email stock etc.
but i make a aroma installer for you with the stock apps , sow you can choose with apps you want too install with cwm recovery.because not everyone use this apps ok.
but first see what works or not .
the cwm recovery is also made by me with touch support now.
hope it works fine with this tablet.
here's the link.
link aroma callibration zip
install this zip with cwm recovery.
use the + and - buttons to navigate , power for confirm.
click the circle with the finger . if it not works use yes on the first question instead of no
if all goes well @ the end you have 8 boxs with numbers.
write it up correctly end give it too me .
when i have these numbers i can make the aroma zip installer with stock system apps and user apps ok.
otherwise the touch screen won't work in the installer.
ps.
don't break off the rom its fantastic on the 10b G3
test it and tell me what not working.
and i try too fix it.
donation link
Verstuurd van mijn ARN10bG3-Freaktab met Tapatalk
