MIII Internet speed
try finless 2.0Bugs are Sons of Glitches!
JustMe
Originally posted by ganjero View PostDoes fitness put something in firmware to speed up wire internet?Bugs are Sons of Glitches!
JustMe
Originally posted by ganjero View PostIs there a way to improve hard wire internet speed on this box? I get 120mb in al my devices but this box. It is hardwire and gets about 12mb and if I turn on the VPN (PIA) it s goes down to 3mb.
Sometimes there exist incompatibility between 100Mbit devices/cards at 1Gbit switches/routers...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by ganjero View PostI have the box connected to my router, I used speedtest.net app to test the speed. Xbmc works ok without my VPN on. I turned on my VPN (PIA) and the speeds dropped down and when using xbmc everything through the internet takes a really long time to load.
vpn will drop your speeds, don't expect speed like your normal ispBugs are Sons of Glitches!
JustMe
Re: MIII Internet speed
Originally posted by JustMe View Postvpn will drop your speeds, don't expect speed like your normal isp
Originally posted by ganjero View PostI understand that but it shouldn't be 3mbps when I have a 150mbps plan. Without the the VPN I get around 12mbps...my other devices are close to 100 or above even when using the VPN service
do you have link to your firmware?Bugs are Sons of Glitches!
JustMe
thats should fix it just noticed you have 2gb version let me know if you have sleep/wake issues after sleeping for 15 minBugs are Sons of Glitches!
JustMe
There are currently 2617 users online. 0 members and 2617 guests.
