MIII Internet speed
Originally posted by Ronin View PostHi JustME, i cant seem to replicate your sleep /wake issues on both OMAN 1.9 and Finless2.0. Box comes back to life fine just fine after 15 min. Doing suspend mode also works perfectly.
thanks Ronin can you try for 1hr power off by remote and then power back on by remoteBugs are Sons of Glitches!
JustMe
Finless 2.0 helped increasing the speed, not exactly what I get with other devices or close to my ISP plan speed limit but it did go up.
Now I am just facing an issue that I do not have with other devices, when I turned on the VPN I cannot get access to my smb drives. I thought the VPN would only affect access to the internet while the local network is not affected. My other devices have no issues accessing my smb drives while the VPN is on and I did not configure them differently.
How can I keep the local network free/unaffected while using the VPN services? Again this is using the MXIII 2gb box with finless 2.0 firmware and Private Internet Access (VPN).
There are currently 1515 users online. 0 members and 1515 guests.
