nextbook 7s resistive screen cant calibrate
more info
Are you using stock rom?
If not, what rom are you using?
Is this a "first run" calibration going wrong?
If not, was anything installed prior to the error?
Out of curiosity, would there be a file named "ts-calibration"
on the root of your sdcard? Just trying to get an idea...
kuazar"Let me tell you why you're here. You're here because you know something. What you know you can't explain, but you feel it. You've felt it your entire life, that there's something wrong with the world. You don't know what it is, but it's there, like a splinter in your mind, driving you mad."- Morpheus
nextbook7 #0811 with heavily modded finless 1.4
huawei activa4g rooted, cwm, mihome
ok.
Two things.
Try to reset the tab: in the back there should be a reset cavity
that you can reset with a paper clip. Turn it back on. Anything?
The other thing is: Does this tab come with a stylus?
If so are you using the stylus to calibrate? You should.
Let me know..
adb
Do you have access to adb?
if you do
If you do, can you tell me the output of "dmesg | tail" without quotes
ok
Work with me here.
If the screen is locked and you then unlock.
The calibration screen reappears?without knowing whats really
going on i was thinking a factory reset. I have read that pluging a usb mouse
to the devices helps touch screen calibration app to close. But i dont know.
If you try this and it works. Do a factory reset.
The only other option would be to reflash Finless' rom.
But that wont resolve anything if it happens again.
Sorry, but without knowing what is going on through adb,
I guess you can say I am blind.
Sorry I couldnt be more help.
kuazar
Edit: for future reference, and anyone else that may have the problem, I suspect
the issue "may" lie in: /system/usr/idc/(whatever-the-name-would-be).idc
Just an un-educated guess..
Hope this helps...
(REF: http://source.android.com/tech/input...#touch-device- )Last edited by kuazar; 25 September 2012, 05:46."Let me tell you why you're here. You're here because you know something. What you know you can't explain, but you feel it. You've felt it your entire life, that there's something wrong with the world. You don't know what it is, but it's there, like a splinter in your mind, driving you mad."- Morpheus
Thanks For The Help
Thanks for the help. But i have tried all of that and nothing is happening i'm going to get in touch with nextbook and see what they say. I have had this tablet for about two month never had this problem before.
i did a factory reset and i reflashed finless rom when i did i could see the home for a min then it went right back to the recalibration screen
sorry
Originally posted by shylovergirl View PostThanks for the help. But i have tried all of that and nothing is happening i'm going to get in touch with nextbook and see what they say. I have had this tablet for about two month never had this problem before.
Sorry I couldn't help you with your problem.
Ok I got the calibration to work
I talk to tech at nextbook and he told me to tap a quarter of an inch beneath each target. The calibration is way off on this thing i had to press in the middle of the screen for the top two and in the middle at the very bottom for the last two. I was able to get in to the sd card and these all the files i see. andriod_secure alarms DCIM download getjar lost.dir movies music notifications pictures podcast and ringtone thats it
great!,"
Glad you were able to resolve that.
You could try typing in a terminal " su" and enter, then "dmesg | tail" and enter (without quotes) to see
if it gives you an idea as to what is going on.
By the way somewhere in these forums I read about someone
having the same tab as you with the calibration issue as well.
Turned out it was that there is another model and he flashed thewrong
rom. If I findthe link I will add it to the end of this post. Something to
Look into if the problem returns.
kuazar
Last edited by kuazar; 28 September 2012, 04:54."Let me tell you why you're here. You're here because you know something. What you know you can't explain, but you feel it. You've felt it your entire life, that there's something wrong with the world. You don't know what it is, but it's there, like a splinter in your mind, driving you mad."- Morpheus
There are currently 3614 users online. 1 members and 3613 guests.
