Square M8 Can't boot into recovery
Originally posted by convict View PostI have the square m8 with 1 gb ram and no bluetooth from bluetimes and i can't boot into recovery, therefore i can't install another rom. I' ve tried everything. Any help please?
toothpick in av holeBugs are Sons of Glitches!
JustMe
RK3288 Devices
- Overview BOX (LINK !)
I know there only exist OTG via a jumper patch but there also exist adb via wifi:
Code:adb reboot recovery
RK3288 Devices
Isn't it possible to boot the recovery.img via sd card?
Maybe you should use one of the updates which contains a recovery.img and delete all other not need stuff (e.g. img/zip) at it...RK3288 Devices
Originally posted by no_spam_for_me View PostIsn't it possible to boot the recovery.img via sd card?
No, sorry, but I think I often read about problems by flashing new rom via SD because of missing the recovery.img at that SD, so I thought, maybe it is possible to use one of these updates with an recovery.img at the SD BUT without the update-files (e.g in img/zip format)...
But I think you also need this script file ('xyz.aml' or something like this (I forget the name))...
And the idea/hope is, that the flashing process will crash because of missing content but will use the recovery.img at the SD so you are at that moment at the recovery... BUT only an idea???
I don't think that a "boot" SD will help, especially you need a fitting uboot which I think is missing for this device ???RK3288 Devices
Also have same problem with this box , pressing pin does not enter recovery mode , only loads to a screen asking for PIN number , box is my dads who is disabled and he says he never set up a pin , any links to the proper files i.e the rom and recovery file would be appreciated as I'm a new member and have been struggling to navigate the site properly yet Thanks
There are currently 5542 users online. 0 members and 5542 guests.
