vigica c70 dvb s2
    vigica c70 dvb s2
    Hello
    I purchased the device above : http://www.aliexpress.com/store/product ... 27217.html
    Device AMLOGIC 8726 MX g18ref th12
    I want to update from this site : http://hdbox.ws/
    Somebody told me that if there are models that have a built- wifi then CCCAM not work .
    and they developed patch that cancell the built-in wifi.
    Which Rom should i chose from there?
    I tried with Google Translate but with no luck please help.
    Thank you .
    Originally posted by aela111 View Post
    Hello
    Thank you .
    hello friend,
    maybe you can upgrade the newest firmware from https://mega.co.nz/#F!qFJhxCSQ!r8bKuAfRczjyvg2Z1V9GIg
    Vigica C60S/ Vigica C70S Android with DVB-S2
    Vigica C60T/ Vigica C70T Android with DVB-T2,
      Hello
      Thank you .
      Hola... i have vigica, i sell in **** and amazon. cccam no working?
      what'r problem? i work it good.
        C70 +C60
        Originally posted by tinahtl7004 View Post
        hello friend,
        IM TESTING BOTH
        I HAVE UPLOADED LATEST FIRMWARE
        NEWCAD SET UP
        I MANUALY INPUTED 110 AND 119 AND ALL TP
        PICTURE IS GREAT
        SWITCHES CHANNELS FAST
        BUT HERE IS THE PROBLEM I NEED HELP WITH
        WHEN CHANELS ARE SCANNED IT WILL LIST EXAMPLE
        CH # 2 NO NAME 121
        NOW WHEN U SELECT THIS IT PLAYS THE H CHANELL AS IT IS CHANEL 121
        I HAVE TRIED THE BUILT IN CHANNEL EDITOR USELESS
        THIS NEEDS TO BE CHANGED TO CH#121 h CHANNEL BUT I CANT .
        ALSO EPG WILL NOT POPULATE NO MATTER WHAT I DO
        ANY HELP PLEASE
          maybe you update the newest firwmware 20141205, it have 10 groups favorate channel list. but chanage name it seems only can use remote control. but can make a try.
            thnx for reply i am on 20141205 .
            i have used chanel editor but its not working well
            WHEN CHANNELS ARE SCANNED IT WILL LIST EXAMPLE
            CH # 2 NO NAME 121
            CH #3 NO NAME 195
            CH#4 NO NAME 200
            CH#5 NO NAME 100
            NOW WHEN U SELECT CH #2 IT PLAYS THE H CHANNEL AS IT IS CHANEL 121
            CH #3 PLAYS MIL**** CHANEL WHICH IS CH 195
            ALSO EPG WILL NOT POPULATE NO MATTER WHAT I DO EVEN IF I STAY AT CH 200
              channel edit
              CH # 2 NO NAME 121
              CH #3 NO NAME 195
              CH#4 NO NAME 200
              CH#5 NO NAME 100
              just now the channel edit cant by PC. only can use remote control. your problem we have take it.
              will reply to engineer.
                Default firmware is soo crappy loking android. There is VITMOD 1.2 - 1.5 alpha 1 which runs from SD card and you get OpenElec. All you need is to upgrade your android with boot_sd.zip and thsi will enable to boot from sd card when it present and boot to android when dont.
                All this you can get in earlier mentioned website. But i have problem that after some time it just doesnt boot anymore... maybe sd card gets corupted..
                NEVER believe in chinese promises.
                  Hi, i have C70S i am happy but i wish to can boot openelec, i search vitmod but i only find about C60S , when i get files to boot??
                    I dont think that there is any difference between c60s and c70s exept design. c60s better because of metal case IMO.
                    Vitmod openelec supports native remote control, wifi, FullHD. everything is pretty smooth. but as i said after some time (in day or two) it stops booting (at least for me).
                    ALSO note: sometimes android stops booting too, shows recovery. dont afraid - do restart system and it boots again dont know why that happens.
                    PS usfull link: http://dvbdroid.info/
                      Thanks, I have dual bot android & openelec by sd card, it is great, now next step configure tvheadend to scan channels...
                        its not hard but i think you have to use specific version of tvheadend.
                        if yours dont work you may trys those (upgrade from top to end) install via xbmc install add-on from zip:
                        service.multimedia.tvheadend-3.9.2108_xbmc.zip
                        update to: service.multimedia.tvheadend-3.9.2168_xbmc
                        service.multimedia.tvheadend-3.9.2182_xbmc.zip
                        (download button at right, not that big one ZIP in center)
                        Also pls leave here replay is yours openelec works after few days.
                          Thanks! I will test in the next days and leave here the status of my openelec. thanks
                            Waiting for your replay
                              Hi, for now all is ok, no porblem with openelec, if i want to run android the first boot open automatically recovery and i have to select reboot now and start in original android system, i get connect and tune channels from tvheadend and now i am trying to run oscam, i having problem to connmect with tvheadend
                              regards
