NEOCM9 Hybrid ROM Version 1.0 for Arnova 9G2
    Re: NEOCM9 Hybrid ROM Version 1.0 for Arnova 9G2
    its the same like my tablet has.
    sow if i understand this is when you now connect your tab than says rktools found rk....... .
    but when you flash it again its still the same
    Verstuurd van mijn GT-S5660 met Tapatalk
    if you love my work please buy a coffee
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
    </form>
      AW: NEOCM9 Hybrid ROM Version 1.0 for Arnova 9G2
      There was no more need. I have recover and returned to stock rock also provided by finless. Now i will try the neocm9 again
      Gesendet von meinem GT-I9300 mit Tapatalk 2
        I duely hope it works i love cm versions
          Snakekiller i flashed the stock 9g2 to recover an it worked. Now flashing neocm9 failed again. Result = blackscreen
            so the tablet flashed fine with stock rom
            </form>
              I am following the instructions and its not workin...
                i had blackscreen too but after stockrom too .you have luck .
                </form>
                  yes
                  yes my luck, but it only stretches so far that i can have stock. but no CM... i think i get stuck in loading the cwm.... why why why why???? i want CM9
                    dont worry i read that hes making a update .
                    so the next version maybe works for you
                    </form>
                      Cool cool i cant wait until then i will run gingercomb
                        When do you think the update will be coming?
                          Tomorrow the Update will be come and you can use it.
                          Kind Regards
                          Rainer
                            Cool i cant wait. Will it be cm10 or cm9?
                              [QUOTE=maawii;29551]Cool i cant wait. Will it be cm10 or cm9?
                              Gesendet von meinem GT-I9300 mit Tapatalk 2[/QUE]
                              I have Updatet both Rom.
                                Sweet!!!!
