NEOCM9 Hybrid ROM Version 1.0 for Arnova 9G2
    Re: NEOCM9 Hybrid ROM Version 1.0 for Arnova 9G2
    you must uninstall the drivers and reboot again.
    than try too install the drivers again.
    if this works and you plugged in your tablet and rk tools say found ..... .
    than your tablet is already on flashmode.
    i had this too with the cm10 rom from him.
    but cant get out of flashmode even after several reflashes and pushed the tablet too the bin.
    maybe you have more luck.
    Verstuurd van mijn GT-S5660 met Tapatalk
    if you love my work please buy a coffee
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
    </form>
      hey neomode where are you ?
      </form>
        AW: NEOCM9 Hybrid ROM Version 1.0 for Arnova 9G2
        I believe i too am stuck in flash moduey, aside from the fact dat my Windows doesnt recognize the device. There must be a way to geht out though. I googled a bit and i found that the 10g2 has a hard reset. I am going to try if this one does too, maybe somebody knows something here. It would be a shame if i had to toss the tab.
        Gesendet von meinem GT-I9300 mit Tapatalk 2
          I think after the image installation the button for the recovery mode has changed.
          Try to hold the menu button and reset. Hold the menu button until the device is recognised. Now you should have a working device for the recovery mode.
            Don't toss the tab. Do you run linux ?
            900Supersport
            freaktab developer
              Yes i got an ubuntu installation. Have you got instructions to recover?
                Problems with this ROM
                Hello,
                So i am back again, i got the Flu.
                So tell me wich Device you have, and was is your Problem with it.
                Then i can help You.
                Best Regards
                Rainer
                  Device: arnova 9g2
                  Problem: apparently stuck in flash mode, no longer recognized by windows, all i have is a black screen, rkflasher says found no device, wenn i try to reinstall the driver to the unrecognized usb device windows says driver is not correct.
                  I think thats it
                  I a linux box and a windows box to try to save with.
                    Open a terminal, and enter lsusb and press enter.
                    Then connect the tab via usb and enter lsusb, we are looking for a new entry for you tab, if it's rk based it will be something like 0x281, 0x300a or 0x290a
                    If we see these then we definitly have options for flashing.
                    900Supersport
                    freaktab developer
                      Recovery Problem
                      Hello,
                      Please try this.
                      Just press both Menu + Power buttons, press the reset hole , after 5 seconds windows dong will inform: unrecognized device,
                      RELEASE the reset hole FIRST (still pressing both Menu + Power buttons) ...
                      Now Windows should find the Tablet.
                        I will try neomode first although i have tried that.... but once more wont hurt
                          Ok so doom was right... menu and power didnt work. Menu alone caused my pad to be found.
                          Now i am trying to flash this rom. I hope it works. It didnt yesterday.
                            Ok it didnt work... all i have is the black screen about but recognized
                              I am coming from finless ics rom
                                Rom Problem
                                So have you try with Linux ?
                                Did you see there the Tablet ?
