Stupidly i had powered the unit up, then plugged in the HDMI cable, which turned the blue LED off.
The box is currently displaying the home screen, the LAN lights work as does the optical audio glow red.
But the box is frozen in state, remote will not respond, blue led is not illuminated.
I can enter recovery mode, but i cant use the remote to select any options.
I also plugged in the WDTV power supply for a short time, but the specs match.
HDMI lead was already plugged into TV, maybe it fried something?
This happened to anyone?
