[Pipo-Project] M8HD kernel
    Originally posted by raxy View Post
    bravo !
    next step could be help us ,other tablet kernel dev, jump on the train and have a 'working' build tree on our own.
    seems possible ?
    tks.
    Pipo sources shared to FT devs
    I've analysed the Pipo M8HD code and compared to 'my' public Rk3188 repo. I've retrofitted a couple of drivers that we didn't have (battery and newer touchscreen) and messed with the mipi driver.
    I can now boot my tablet using a kernel built from 'my' public repo but it isn't stable.
    Test kernel
    Donate to Finless
      is anyone testing either of these?
      Donate to Finless
        I have tested the first one from Pipo Sources but not long as I try to build Cyanogen for M8Hd now
        I will do it next week
          Only m7pro over here, so no go....
            Same here, only M7 Pro, M8 Pro, M6 Pro and U8...but no M8HD to test.
            I can't even find one to buy anywhere at a decent price.
            Randy
              Then post up DMESGs of the models you have and I'll see what I can do. Most important is to know the exact model of the LCD too.
              Donate to Finless
                Not had time yet my daughter using my pipo m8dh this week but will give them ago when she back at school next week and give you some feed back
                  Test kernel
                  I have managed to to get hold of my m8hd and this kernel boots but if charger is plugged in it dose not boot and i get a black square in the top right hand corner
                    sorry I mean left
                      Please find it here
                      s000.tinyupload.com/index.php?file_id=01053356016881467381
                      And tell us some good news
                      Tks !
                        According to different sources,
                        The tft panel of the m7pro is the same as kindle fire 8.9 hd's
                        It is a Samsung ltl089cl02-001
                          I started a thread for M7pro here
                          Donate to Finless
                            NFS/CIFS/usb audio test.
                            [edit] fixed @ version 1.10
                            so I have tested a little more
                            all modules are detected present in kernel : if i load them manually : it tells me it's already in kernel.
                            Then I have tested usb audio : it 's working good for me but maybe need also my patch of service.jar.
                            modules are not needed anymore
                            I can mount a nfs share by terminal now, but can't access it with other application due to kitkat maybe.
                            command is :
                            busybox mount -t nfs -o nolock XX.XX.XX.XX:/export/share /mnt/mount_point
                            For cifs, mount manager app mounts it , no crash but can't have access to files.
                            by terminal none command works, I can't find it !
                            But esexplorer does it well, so no problem for me
                            So Far So Good.
                            PS : can you share me your config to see If I was good
                            My build kernel boots well too but didn't test it much
                              command is :
                              So Far So Good.
                              My .config is in the github but you can extract it directly from the kernel too.
                              Donate to Finless
                                I've moved this thread to the new Development Projects sub-forum.
                                Randy
