I'm guessing there must be other changes as the remote file you posted gives me no response (tested a second time, fresh install of rom) I thought the opening post sAid this remote was fixed? Or have I missed an update link?
OpenElec on EM8
Originally posted by MetalKettle View PostI'm guessing there must be other changes as the remote file you posted gives me no response (tested a second time, fresh install of rom) I thought the opening post sAid this remote was fixed? Or have I missed an update link?
Remote is fixed and worked quite well apart from the e broswer button, back button, mouse button on roundish remote and original square m8.
- v0.92 and roundish remote
H8 and m8n had the issues which zahir fixed remotekeys for on those boxes.and posted remote.conf scriptBugs are Sons of Glitches!
JustMe
1. Neither the remote config in JM's beta release, shared with all of us, nor the one in his later release shared with me (and posted by me as "originalremote") works fully.
2. The 98 per cent solution is the config file I first linked over at Mega. That one does everything except power up. It works for me and for Trebor, it seems. Maybe others can report their mileage?
Hard to say why an adept like you, Metal Kettle, hasn't got that one working. You have all the skills, so your remote must be slightly different.
Originally posted by JustMe View PostRemote is fixed and worked quite well apart from the e broswer button, back button, mouse button on roundish remote and original square m8.
PS, there should be $40 from me in your in-box. Not enough recognition for all that you're doing, but a start...
Originally posted by MetalKettle View PostOk. So the remote file supplied is not compatible with my m8. Must be a different version. I'm now looking to get the remote working through an xbmc keymap instead of a linux remote config.
Originally posted by Zahir View PostThat explains a lot, JM, it's those two boxes I've been working with and for which my remote script does work.
Thank you kindly Zahir...it also my birthday today, so being spoilt from few people today.
JustMe
Using Zahir config
copied to /storage/.config
CheersLast edited by trebor; 22 October 2014, 23:47.
Originally posted by MetalKettle View PostOK. Heres my xbmc keymap. All buttons 100% working on my version of the box.
copy to userdata/keymaps in xbmc.Bugs are Sons of Glitches!
JustMe
There are currently 3058 users online. 2 members and 3056 guests.
