OpenElec on EM8
Originally posted by trebor View PostYep been there....just missing a setting I am not familiar with I feel.
Command: open "[email protected]" 22
Command: Trust new Hostkey: Once
Command: Pass: ********
Error: Authentication failed.
Error: Critical error: Could not connect to server
Thanks for your time
Just want to throw this out there. Are you enabling ssh in openelec settings. It's usually disabled by default and samba is enabled by default.
Originally posted by MetalKettle View PostYes. Tried that as well as creating ssh_enable in config.
I have an M8 I picked up a couple months ago. Its just sitting around collecting dust, I'll give this shot and see how it goes.
Also what rom are you installing this OpenELEC rom over.
Originally posted by Zahir View PostDon't know why it works for me, and not some others. My board is nothing better than an H8M8 V2.0.
Here are the exact steps I followed. NB: all I used was a Logitech USB keyboard plugged in at the outset.
1. Remove SD card (with the rom files on it) Note, these are the files INSIDE JM's download.
2. Use toothpick to get into stock recovery.
3. Insert SD card with all JM's files on it.
4. From recovery menu, perform factory reset.
5. From recovery menu, wipe cache (yes, again)
6. Select Install update from Ext, navigate to rom zip and install
7. When installation is done, do another factory reset from recovery.
Power off and restart.
Are you actually opening up the zip and putting all the files on the root of the sdcard? I tried that and when I go to EXT all I see is meta-inf and system.
I was able to install the this rom with just putting the zip on the sdcard, but go stuck at Openelec
What we have:
1. Really fast box. No Android build compares. Equal to, if not slightly quicker than Armada Pure Linux. In all functions.
2. Superb video playback. Smoothest yet.
3. Efficient wired LAN.
What we need:
1. Effective power management scheme via remote.
2. HDMI-CEC implemented
3. Multiple remote selector
With those three developments, we'd have a giant-killer of a box.
Originally posted by borikua View Poststrange. no matter what I do or how many times I do this here all I get is a quick openelec logo and then it goes away and l loose tv connection. I also have H8M8 V2.0
I'm installing the android firmware back on and then installing this build over that to see if it makes a difference.
Originally posted by al8782 View PostSame here the openelec comes up quick but I just get the Openelec splash screen.
Originally posted by borikua View Postif that does it for you please let me know... which android rom. I tried by doing finless 1.8 first but no luck.
I'm just going to wait for Codesnake's build for the M8. He mentioned it should be out in a few days if all goes well.
I found if TV Signal is lost, TV or Box is in wrong resolution (remembers something)
I was changing cable, monitors, removing switch boxes.
I reloaded JM android left it in 720 mode not 1080
Reloaded openelec full wipe ,and woo woo went all the way thru.
And yes ssh was enable with and with out password
Still cant FTP or SFTP.
Cheers
Originally posted by trebor View PostI found if TV Signal is lost, TV or Box is in wrong resolution (remembers something)
Cheers
Cheers
There are currently 1786 users online. 1 members and 1785 guests.
