OpenElec on EM8
Originally posted by al8782 View PostIt's just not working with my box, all the other roms I install work. I have the M9&M8_V0.92
I'm just going to wait until Codesnake finishes his rom. I use his Openelec rom on my Mx2. I'm pretty sure he has the same box as me.
I'm also waiting for codesnake then i'll have 2 openelec builds to try on this m8 box.
Originally posted by snelsy View Posti have the same box as you and managed to install openelec did you set the video to 720p before you tried openelec? i didn't at first and couldn't install.
Im installing on a 26 inch vizio and in finless rom it's already set to 720. Maybe I should try my bigger tv and see if Finless's rom is set to 1080 so.I can manually set it to 720.
O
Not sure on this.
Does the AV out work the M8 (where you stick the toothpick in) and if you
have a cable to suit and a TV with RCA in may be an option.
Originally posted by al8782 View PostYes it's set to 720 and it's even set to 720 by auto detect. I tried 720 60 and even 720 50 and still no go.
O
O
Originally posted by snelsy View PostThe finless rom i tried 1.7 was set to 1080 and i manually reset to 720p that may be your problem i'm using a 60" lg tv
You can sometimes tell what resolution a Finless rom is set at right from its boot screen. It'll say 1080 or 720.
Re: OpenElec on EM8
Originally posted by polys View PostIs codesnake also working on an Openelec build for the M8? If yes, will he be announcing it here?
I have a 60 inch in my living room I'll try it on.
Originally posted by al8782 View PostYes the rom says 1080p and when I go to mboxsettings and then more settings the display is set to 720p 60. I think it's set for auto detecting setting. For me to switch to a different setting I have to turn off auto detect.
There are currently 1576 users online. 2 members and 1574 guests.
