Give it a go. The resolution was key before. Not sure if that was fixed in beta 2. But worth a shot. Do a factory reset before and after installing OE.
OpenElec on EM8
Originally posted by MetalKettle View PostDid you get it installed? Same process as before?
Also after a few minutes of a blank screen (time to load) hit the return key 5 or more times
if you have kyb, then power off on remote many times it also kicked in
and looking north while eating pizza also helped
Cheers
Try a different Android Rom to set up the 720,
Stanes Android or a Finless if not already
Cheers
Originally posted by foz View Poststuck on amlogic logo ths time
tried factory reset again and reboots
Originally posted by foz View Postthe just me 1.2 final works every time but can not get past boot logo splash on either b1 or b2 with this
foz
you should get quick flicker of the green amlogic logo and then boot straight into OpenELEC tried it over 30 times on m8 I will download the file and test the uploaded one to make sure it the right one i uploaded Openelec beta2, beta 1 had issues for allot of people getting stuck at boot second boot logo screenBugs are Sons of Glitches!
JustMe
beta 2 definitely working no issue on boot ups 15 to 20 seconds even power off and suspend working 100%Bugs are Sons of Glitches!
JustMe
Something differant on these M8 boxes from totalxbmc mk1 S802 K200 I think
bob has got the original rom
1 lad on forum has got it on and working but 2 off us it simply won't go further than splash screen
Been trying all differant things for over 5 hrs
it's really strange flashing jm1.2 final works every time same method of installing it
shame really wanted this port
Foz
the first splash flashes up but then it comes back to same Amlogic splash
The install seems to be successful every time but same problem
tried USB SD cards ie Firefox to download file 720 p in old os
Every combination really of All things we can change
differant tv's monitors etc reboot from recovery pulling power etc etc etc etc
Originally posted by foz View PostSomething differant on these M8 boxes from totalxbmc mk1 S802 K200 I think
Foz
differant tv's monitors etc reboot from recovery pulling power etc etc etc etcBugs are Sons of Glitches!
JustMe
There are currently 2185 users online. 1 members and 2184 guests.
