OpenElec on EM8
Originally posted by polys View PostNo it doesn't. I tried codesnake's Openelec 4.95.2 and iStream was incompatible.Bugs are Sons of Glitches!
JustMe
Originally posted by mcfctrublu View PostHello all,
Really struggling to get this justme openelec installed on my TRMk1. I've tried twice now unsuccessfully and had to put justme oman back on twice.
Here's what I've been doing...........
Tried on USB stick first and failed then decided it had to be micro SD card but still failed.
1- set resolution to 720
2- downloaded justme openelec beta 3
3- transferred it to USB/micro SD
4- unzipped in USB/SD
5- booted into recovery using toothpick method
6- wipe data/factory reset
7- wipe cache
8- apply update from EXT
9- update from SD card, also udisk
10- justme_openelec_beta3.zip (seems to work, states "openelec installed successfully"
11- factory reset
12- reboot
It just shows the cats eyes of justme and sticks
reboot again.......the same
turn off/on at switch......the same
reload justme oman
EDIT Can't reload justme oman now. Help
JustMe
Originally posted by mcfctrublu View Post*update* flashed justme openelec now. Dead easy.....had to do it twice but really quick and easy this time. Thanks to all that helped me with thisBugs are Sons of Glitches!
JustMe
Hi JustMe
I load the beta3 with toothpick method and completed ok,
but after reboot the box came into the first openelec screen (the one that I have to configure the system -language, samba) and it freezes.
I reflash it again but the same result, freeze.
Before that,the box had your android version 1.3 an was working perfect.
I load it again (android 1.3) and it works perfect
Everytime between flashing I do a factory reset.
Any hlp pls becase I want to use it as an MediaPlayer ony and the XBMCopenec version is perfect
thx
thxBugs are Sons of Glitches!
JustMe
There are currently 1814 users online. 1 members and 1813 guests.
