OpenElec on EM8
OpenElec on EM8 Armada Mach 8
Originally posted by MetalKettle View PostHave you played with the sound settings in xbmc? Are you using hdmi for sound?
Post #1 updatedBugs are Sons of Glitches!
JustMe
Makes you wanna buy another M9&M8_V0.92
All this new stuff about
onya JM
Cheers
Rom size is smaller than other two and smaller than your first beta is it all there ?Last edited by trebor; 27 October 2014, 09:45.
M8
S802 K200
total xbmc Mk1
Beta 2 seemed to install fine but I get a very quick splash logo S802 flash up then black screen
tied flashing 3 times same result tried different tv another lad on forum having same trouble but 1 lad has it working same boxes
it installs fine goes through and completes without errors
installed followed these instructions
1. Remove SD card (with the rom files on it) Note, these are the files INSIDE JM's download.
2. Use toothpick to get into stock recovery.
3. Insert SD card with all JM's files on it.
4. From recovery menu, perform factory reset.
5. From recovery menu, wipe cache (yes, again)
6. Select Install update from Ext, navigate to rom zip and install
7. When installation is done, do another factory reset from recovery.
Power off and restart.
any idea's?
foz
There are currently 1703 users online. 1 members and 1702 guests.
