foz
OpenElec on EM8
audio distortion
Hi. I am just on the latest openelec for em8 box. I am getting audio distortion when a mp3 is played, and thats happening after couple of minutes or so. If i make any change in audio settings it stops for a while but then starts again. Its happening on hdmi and spdif out is well. Anybody can help. Thanks.
Originally posted by Krankie View PostDid you have any success ?Originally posted by trebor View PostDid you have any success ?
Cheers
but I will test Justme's unofficial rom when he gets chance to upload it
hopefully i will get it working before then
Originally posted by foz View Postno get stuck at logo just flashed it again leaving it on logo now for 30 mins worth a try? then I will go to recovery & try reset again
CheersBugs are Sons of Glitches!
JustMe
@justme
regarding installation on the trmk1 box, we believe it may have something to do with the resolution settings, could this be possible or should the rom automatically set to the tv's default?
Also on another note... wifi is on, then i reboot the box and it's gone... then i reboot and it's back.
Just a heads up.Three days of testing can save 10 minutes reading manuals
Ok, I was asking Krankieas he was having the same problem as you....
Keep at it
Cheers
OK guys. Try my files in the following link...... Ive tested numerous times (with different Roms before the flash) and OE boots each time.
1. Boot into recovery (without SD card inserted) and do a factory reset.
2. Boot into recovery by toothpick method (with SD card inserted) and the ROM should auto install, reboot, and boot into OE fine.
Let me know how you get on.
Ok just to update you all on how I've successfully installed on the trmk1, this is most likely not the "correct and cleanest" way of installing but it worked for me (after much trial and error)...
1. Flash the latest JustMe_1.3 Android version (I love the boot screen and especially like the logo in the top right - nice work sir!). I installed this from USB in recovery but presumably SD would work too.
2. Change resolution to 720p 60hz
3. Click on the reboot app and enter recovery
4. Wipe cache partition & factory reset
5. Flash the OpenElec JM b2 version via USB (presumably SD card will work too).
6. Reboot, stuck on the M8 logo.
7. Enter recovery and do a factory reset & reboot
8. Should now boot into OpenELEC, mine was stuck on a black screen but I found if I switched my AV receiver to another source and then back to the correct one OpenELEC was there and working - went into resolution settings and changed to 1080p. Streaming 1080p 5.1 video via wi-fi without any issues
GREAT WORK JustMe - this is marvellous (just need to work out how to get this standard square remote working now)
OpenElec on EM8
Originally posted by whufclee View PostOk just to update you all on how I've successfully installed on the trmk1, this is most likely not the "correct and cleanest" way of installing but it worked for me (after much trial and error)...
I found a factory reset after the Roms was installed would break it lol
There are currently 2542 users online. 0 members and 2542 guests.
