tronsmart vega S89 ehernet poor performance/stability
    Originally posted by lawin1 View Post
    Try this solution (Bionic TCP Buffer Tweak):
    http://www.freaktab.com/showthread.p...l=1#post199314
    I'll check it on my S89 and WiFi access . Thx.
      If I am not wrong Finless 2.0 ROM already include these patches.
        Yes, you are right.
          Yes, you are right.
          And on the first topic he wrote that he tried finless 2.0
            I had try this trick on the stock rom and ....... it seems solve the problem.
            Without doing anything else I am able again to play video from my lan without problem.
            Browsing seems ok too. (exactly like before)
            Is it a miracle?? or hazard?
            BUt has tiguy82 said I had already test with finless 2.0 but the problem was here. Are you sure that this fix has been implemented in finless?
              Originally posted by ooznerol View Post
              Check point 13) : http://www.FreakTab.com/showthread.php?t=17703
                Yes I have seen this point but it seems that settings apply in finless rom are not the same settings from the post that you mention
                I had reflash the finless 2.0 rom and use bionic TCP to read current value.
                In finless ROM I have :
                read buffers 4096 87380 256960
                writebuffer 4096 16384 256960
                with large TCP buffer I have
                read buffers 4096 1048576 2097152
                writebuffer 4096 524576 2097152
                So maybe finless has missed something.
                  There is a hope that ethernet performance problems will be solved in future 110k4 firmware (point 14):
