I have a tronsmart vega S89 since one month now (fw 108). Until few day everything was perfect. But now my ethernet connection is very bad : very very low bitrate / seems not stable. If i disable ethernet and re enable it the connection seems working few minute and after problem reappear. I had no problem with wifi. I had done factory reset problem always there. flash finless 2.0 : same. I had change cable between vega to my box : same
Is there anybody to help me?
thanks
