[REQ] 1080p Kernel for New T-R42 B351_V4.21
    Hello Guys
    Got a new T-R42, has a new board with RTL8723AS WIFI/Bluetooth.
    Stock Kitkat which works flawlessly expect that its 720p.
    Using the current Antutu gives just over 21400.
    Wasser Kitkat or any other T-R42 firmware bricks it.
    Any ideas to get up to 1080p.
    Stock firmware:
    Archive name: T-R42 BOX RK3188 for V4.21-163162-20140930
    Image file name: B351_HW4.2_rtl8723AU_20140820.img
    Support: 8723au WiFi module
    Boot version: 2.16
    FW version: 4.4.02
    . Click image for larger version
Name:	P1050299 (Copy).jpg
    Originally posted by Johnoo View Post
    Hello Guys
    Stock firmware:
    Boot version: 2.16
    FW version: 4.4.02
    . [ATTACH=CONFIG]8530[/ATTACH]
    You can try
    With a 1080p capable kernel, this switches to true 1920x1080
    Must be rooted
    In Terminal, type
    su
    wm size 1080x1920
    If you wish to switch dpi as well, you can do so:wm density 240 //for 1080p or 160 for 720p
    The "am" command works similarly on older versions of Android, with the benefit of not requiring root
    su
    am display-size 1080x1920
    echo "display=0,iface=4,enable=1,mode=1920x1080p-60" > /data/rk29_display.cfg
    Also
    video.use.overlay=1 //change to 0 in system/build.prop file and
    lcd density=240 //for 1080p or 160 for 720p in build prop file
      Ok got it work, thanks
      note for TV box
      `wm size 1920x1080` (1080x1920 for mobile displays)
        Mouse pointer looks like a small fly now.
        Is there anyway of changing it without taking the framework apart.
          Change the DPI in the /system/build.prop file to 240 or 160 depending on the resolution.
            Current setting 240 .
            Does not matter I`ll change it from framework.
              also aspect ratio for movies in xbmc does not look right,
              have to change xbmc setting `pixel ratio` from default of 1 to 1.25 to get it right.
              is the kernel upscaling and its not true 1080p ?
              -- UPDATE --
              only shows up with SPMC.
              other XBMC works fine.
                Hi Johnoo,
                I'm inrerested in this board revision too.
                This manufacturer always produces the best board modifications(B_351...).
                I think the more proper way is to use overlay trick, but not "wm size".
                Does overlay trick work for you?
                CS918II/16GB(HTC-031-V1.0 board)
                CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
                K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
                  I think your device's new 2.16 Loader version causes these bricks with wasser's Kitkat.
                  If your skilful anough to split wasser KK 1.0.4 or 1.0.3 FW to separete images, then you will be able to flash his ROM as separate images but with your 2.16 Loader(just leave Loader row unmarked in flashtool).
                  I'm not shure that it will boot, but I hope flashing process won't be failed.
                    Hi Digger,
                    Im familiar with taking firmware img apart changing/removing system apps etc ..
                    Confirm loader is `RK3188Loader(L)_V2.16.bin`
                    Not familiar with `overlay trick`, any info I`ll give it a try, quick Google did not came up with much.
                      Just gave Wasser a try again, split the firmware, left loader unmarked/off in flashtool etc...
                      Same as before, a few gray lines on the screen after about 10 secs.
                        the overlay trick
                        change `video.use.overlay=1` to `video.use.overlay=0`
                        this changes the resolution on its own to 1080p, no need for
                        "wm size"
                          Help Please!
                          I have the same box and board. Running stock firmware I can get video out on XBMC and Showbox. It is 720p.
                          My wife prefers Netflix and YouTube, but the Netflix video is glitchy, and I get no video from YouTube.
                          Any ideas if there is another firmware to load that will fix this? I've managed to flash firmware from Wasser, but the box powers up to a black screen and then powers off. I've had to revert back to stock.
