Gotham Freeze/hangs T-R42 B351_V4.21
Originally posted by Johnoo View Post
Have you checked the power supply, maybe use 3A power adapter?
You have a very new ROM, so even making a custom kernel with 1080p won't fix the issue. Unfortunately I haven't made a RTL8723 kernel before, because it didn't work. Might see if I can make one but it will take a couple of days for me to see if I can do it.
Found an older firmware that works with this new board.
Download Android 4.4 KitKat firmware for EKB311A / MK888 / K-R42 /Q7 / CS918 TV Boxes from here , here or from here . Archive name:...
this one works at 1080p.
flashing newer kernel with older (2014/07) system.img still works,
indicating that issue is with the new system.
From little I know, assuming it is one the of the system Lib files.
There are currently 1574 users online. 3 members and 1571 guests.
