PTAB8000 Frozen screen no reset
The instruction on the PTAB8000 show there is supposed to be a reset button on the back of the device (pin hole size) but I have two of them side my side and neither have a reset hole. However, I also noticed that the port layout on the bottom of the device doesn't match the instruction either. I can't find a way to reset it to bypass the frozen screen. Is the rest actually under the cover where I need to remove the back panel to access it?
There are currently 1200 users online. 2 members and 1198 guests.
