Turn off (hard boot?) without using "Shut down" feature?
    I have my TV stick (MK809III QC802 RK3188T) plugged into the USB port of my TV so that when I turn on the TV, it turns on as well.
    This works great for us. I just choose "shut down" or whatever, the stick shuts down, then I turn off the TV.
    However, we want to buy our in-laws one for a Christmas gift and it would be easiest to set theirs up the same way as ours. But the problem is that they frequently turn on their TV for watching cable, which means it would boot up the stick too. Is it necessary to use the "shut down" feature? Would it damage the device to just turn off the TV without using the shut down feature first? It's not like there are moving components like a traditional hard drive.
    I've never owned a Smart TV, but I assume that it's basically a built in computer (the "Smart" part of it), and that people can just shut down their TV like a normal TV without having to go to the "Smart" part to shut that part down first.
    Thoughts? I'm trying to wean them off cable to save them big money, but want to keep things as "normal" as possible without extra steps. They're pretty old school, but I've managed to get them set up with hooking their laptop up to the TV and watching Netflix and stuff. A TV Stick with XBMC would be a logical next step.
    Sooo... I guess turning it off without using the "shut down" must screw it up. I have just turned it off without shut down before. But tonight I decided to just unplug it while something was streaming on XBMC.
    Now it won't start up at all. No black screen, no nothing. I see the lights on the stick turn on, but my TV just says, "No signal."
    Hopefully I can re-flash it? I guess?
      Greeeeeeat.
      It appears to be hard bricked. I can't even connect it to my computer. I've flashed it before, so I know what I'm doing. I put the paper clip in the little reset hole thing, plug in the USB into the mini USB port (not the DC port on the bottom) while it's already plug into my computer, and... nothing happens. Absolutely. Nothing.
        I think I know what to do. I need to short the NAND pins, and while I'm shorting them, plug it into my computer in order to connect and flash it. So the shorting acts like a reset button.
        Can anyone tell me which pins I need to short? I have looked at various tutorials and I haven't found one for the MK809III RK3188T.
          Fixed it. *sigh of relief*. See this thread: http://www.freaktab.com/showthread.p...809III-RK3188T
