Draco AW80 - Android OS / Launcher / UI.... issues feedback here
I start some explicit threads to sort all issues and feedbacks from the beginning...RK3288 Devices
- Overview BOX (LINK !)
Fly Mouse Mini Wireless Keyboard with 2 mode learning IR remote 'iPazzPort KP-810-16'Tags: None
FYI
Originally posted by alwaysbless View Post...For instance, it looks like my screen is zoomed out at all times and all icons and text are so small they are barely readable unless im standing in front of the tv or set the font size to 'HUGE'. Its also a tablet rom so it has the status bar at the top which is REALLY unreadable since the icons are even smaller then the ones in the app drawers or on the main screen.
Update: Setting density from 160 to 240 in the build prop sizing issues with icons and video quality for the most part but there still is room for improvement in panning scenes. ...RK3288 Devices
Within netflix the auto-hiding of the status bar also messes with the playback menu (e.g. If I click anywhere on the screen to bring it up it will appear and then re-auto hide). I remember this issue from other devices also and there was an option with the settings menu to disable but it doesnt look like this boxes firmware has that option.
sixaxis
Has anyone tested the sixaxis bluetooth app on the draco yet, It works on all rockchip devices perfect, It don't work on any amlogic devicejust Wodered if it woks on the draco allwinner
Originally posted by blinkone View PostHas anyone tested the sixaxis bluetooth app on the draco yet, It works on all rockchip devices perfect, It don't work on any amlogic devicejust Wodered if it woks on the draco allwinner
Yep its working. I was playing MC4 earlier using my ps3 controller.
Ok, 160 to 240 is an interims but not really nice!
Does anyone find a way to disable this annoying sound at every mouse-click?
I'm missing something like this
Settings -> [DEVICE] -> Sound => Touch Sounds
I'm also missing
Settings -> [DEVICE] -> USB -> Connect to PC
maybe because of missing OTG at Android?RK3288 Devices
Originally posted by no_spam_for_me View Post
I'm also missing
The stock firmware as well lack of "Live Wallpapers" which can be solved installing 3rd party Live Wall Papers but the ones that I had tried none of them had worked (i.e, Magic Smoke 3D Live Wallpaper) which apparently install, but when it´s going to be run or set up just comes an error message saying "app not installed" after that do nothing; this is a problem on the original fw.
Originally posted by BTR11 View PostI´m missing too that option into Settings (USB -> Connect to PC).
Originally posted by Finless View PostThis does not exist in a 4.4 media device anymore. The way you connect to PC is Settings>storage and in the upper right of the screen click the 3 vertical dots. Select MTP or camera device. If one is check it should connect to the PC. BUT it doesn't work right now because none of the USB ports are defined as an OTG port. I will fix that next ROM.
Settings -> ACCOUNTS -> + Add account -> 'Google'
I find no way to generate a new Google account (only able to use an existing account) because it crashes after entering First/Last (not really crashing but goes back to the screen where I can select Existing/New at 'Google' or back to settings)....Attached FilesRK3288 Devices
Zooming out in Google Earth/Maps
The Google Earth and Maps apps that load on the Draco seem to be for tablets with touchscreens and though I can zoom in by repeated mouse clicks on the map, I can't find a way to zoom back out. I have tried a Tronsmart TSMG62C air mouse and also a desktop bluetooth wheel mouse hoping that turning the wheel would make it zoom out, but it didn't. Any suggestions? I am on the stock rom.
NFS - no kernel support
I'm missing NFS support at kernel:
Code:busybox mount -t nfs 192.168.2.1:/nfs-share /mnt/nfs-share -o ro,intr,soft,udp,nolock,rsize=8192,wsize=8192 mount: mounting 192.168.2.1:/nfs-share on /mnt/nfs-share failed: [B]Protocol not supported[/B]
RK3288 Devices
system freezes
Sometimes the system freezes with grey screen during video watching at stock xbmc (didn't often use mx player) but the TV doesn't lost signal...
(can't get dmesg and logcat because also the network isn't any longer available...)RK3288 Devices
Originally posted by no_spam_for_me View PostDoes anyone find a way to disable this annoying sound at every mouse-click?
download the attached empty ogg file.
on your box, navigate to /system/media/audio/ui and overwrite the existing Effect_Tick.ogg.
if not already, set permissions to 644.
reboot, click is gone!
you can of course rename that file and eliminate any other disturbing ui audio effect.
just deleting the ui sound should also work(i think) but i thought replacing it would be nicer.Attached Files
There are currently 3458 users online. 1 members and 3457 guests.
