Draco AW80 - Android OS / Launcher / UI.... issues feedback here
hehehe, ok, that's a way (q&d)RK3288 Devices
- Overview BOX (LINK !)
I have a new problem...
Beside that i'm never able to switch on the box with the remote control(i think thats a common issue, isn't it?), after some seconds it is waking up by itself from sleep, even when powered down. Now i have to pull rhe plug everytime. Another annoying thing is that the screen resolution resets to 720p every 2-3 times i start the box.
Originally posted by frhdt007 View PostRK rom does not suppor Tronsmart remote (does NOT wake up the box), even if you copy the IR file.
Flash any Tronsmart rom of your choice. Mine is Tronsmart 20141219v1 beta .
On the thread he wrote:
A ROM modification based on:
"Stock firmware" Tronsmart:
It's normal that your RK remote doesn't work with Tronsmart rom.
flash back RK rom.
Originally posted by Boxx View Post... after some seconds it is waking up by itself from sleep, even when powered down. Now i have to pull rhe plug everytime. Another annoying thing is that the screen resolution resets to 720p every 2-3 times i start the box.
Originally posted by Boxx View PostI found out that it happens only when my bt keyboard or mouse are connected. i guess they send an impulse that wakes up the box. Doesn,t matter, airmouse is on the way. after removing xposed framework and clearing cache/dalvik, i have no more problem with the screen resolution.
There are currently 3864 users online. 0 members and 3864 guests.
