Pipo P8 RileyROM 1.5 [Android 4.4.4]
    it seems it has the sensor or uses the cam to detect light level. The auto on mine works okay and keeps the option on even when i turn it off.
    But the annoying part is when the battery goes below 20% it automatically reduces the brightness to 2/3 which is hard to see when outside. Can this be disabled?
    Have you tried 3G data with it? Does yours show the 3G or HSPA or H+ symbol?
      In the meantime I have figured out the root cause of the battery drain: it is the UltraStick modem with causes the higher consumption.
      It was already factory installed an as soon as I have taken out the stick, the P8 was able to enter deep sleep mode.
      Jo
        Just wondering if the latest official firmware has the same battery drain issue? I haven't used the official firmware at all that's why I'm asking (went straight to Riley's after unpacking).
        Also, how can I flash the latest official firmware replacing Riley's? Do I do that as normal or should a different procedure happen?
        Sent from my iPad using Tapatalk
          You have to use the RKBatchTool to flash the stock firmware. It and the firmware is available on Pipo's site. http://www.pipo.cn/En/index.php?m=About&a=gujian
          Randy
            Thanks. One last thing, do I have to worry at all about having flashed Riley's with the 6gb parameter?
              You shouldn't. The stock firmware will just take you back to the 1 or 2gb parameter.
              Randy
                #194 released, seem that power save improve after half of day using.
                but stock rom designed 1gb for internal storage only, it dont good enough for most of users. i think.
                #194
                百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
                  Thanks for the info.
                  I'll get to work on a new ROM with the usual parameter sizes.
                  Randy
                    Can someone try v1.6 for me and make sure it boots OK?
                    Download
                    Randy
                      Works very well here - even if it is in average 800-1k "slower" compared to your previous ROM- Let's see if there is some improvement reg. battery drain.
                      I use it with Nova launcher and ART - still extremely smooth.
                      Thanks a lot for your great ROM !
                      Jo
                        Thanks for testing.
                        I'll make a new thread for this ROM.
                        Randy
                          Here's the link to the new 1.6 ROM thread:
                          Randy
