It seems a year later things have moved on a lot!
Im looking for an easy to use, easy to update box that will stream from my mac or play directly from sd card/usb/hard drive. Something that will play 4k would be nice for the future. Need something that can handle 3d.
Also would like something that would be easy for my wife to use who is tech illiterate.
so then, what should i buy?
thanks for the help
