cs908 vs cs918(rockchip)
Which CS918?
I have to ask because meanwhile there exist too many different devices using the same name.
E.g. with or without BT.
Generally the newer devices often use a modded rk3188 called rk3188T which has less power, also worst case you get a device which fake 2GB ram but only 1GB ram is build in.
Because there exist many different devices the chance to find a custom rom for it isn't really good...
I don't know the CS908 but find some threads about CS918S (also Allwinner) here at the sub-forum, e.g.
RK3288 Devices
- Overview BOX (LINK !)
I've ordered 5 of these:
http://www.****.ca/itm/131321986986?...84.m1439.l2649
Since they are listed as having bluetooth they are 1.6ghz and not 1.8 right? It lists the normal 3188 but since it has bluetooth it has to be the t right?
I'm kicking my ass for not finding this website sooner.Also will either of wazzers roms work on these?
I don't think that's a good choice because of 1GB RAM....
I don't know if you will find a custom rom (you have to open the box via the 4 screws under the rubber feet and have a look at the printed information at the pcb)...
Nearly every new device uses the rk3188T which doesn't work/run at 1.8GHz at stock rom (maybe 1.4GHz at stock rom), but rk3188T is independently of BT (two different thinks)....RK3288 Devices
My 2cents: Don't buy a rk3188
Have a look at this http://www.freaktab.com/showthread.p...s918-and-T-r42
Long time a go, before s802 and rk3288, I also thought about to buy another rk3188 because of BT but stopped it http://www.freaktab.com/showthread.p...l=1#post164830
If you really want to buy a rk3188 I think you should ask at
( and maybe also
http://www.freaktab.com/forumdisplay...T-R42-CX919-II )
where to buy a device with real 2GB RAM which is confirmed to work with a custom rom (and also which one) specially with a custom kernel for 1080P ...RK3288 Devices
( and maybe also
There are currently 3230 users online. 3 members and 3227 guests.
