Custom Polaroid Boot Animation 800 x 480
    http://youtu.be/wXDPBuLkZ_s
    Just copy this zip to your sdcard and using es file explorer in root mode mount /system as rw and drop this into /system/media.
    Created with the use of:
    Photoshop Elements
    Poladroid (poladroid.net)
    Re: Custom Polaroid Boot Animation 800 x 480
    Looking good drywall.
    Have you thought about doing a splash image? If I remember right, that file is initlogo.rle
    Also I enjoyed the term PolaDroid for our tablets. Just a couple thoughts from me. I will be adding the boot animation right now
    Thanks again
    Found this for rle files
    Sent from my Polaroid 701c tablet running Cm10
      Thanks again
      Thanks. I will consider doing a splash. I do remember seeing the Poladroid name as well as DarkStar early on. I'm thinking I might avoid those. The DarkStar one because I'm not a fan of it and I don't think it's caught on and PolaDroid is actually the name of the Windows/Mac program I found to create the Polaroid image in the boot screen as cited above.
        Ok, not a problem.
          Wouldn't you have to 'cook' a splash screen into a custom .img file?
          https://public.bay.livefilestore.com...ion.png?psid=1
            Can you post a non Google Drive link? When I try to open it. In my tablet browser, it goes to the aip file @contents@ instead of giving me an option to download it.
            Sent from my Polaroid Tablet using Tapatalk HD
              I have no where else to host it but I can say it does the same thing in a desktop browser too but there's a file menu with the option to download it. Hope that helps you get it.
                Ok so my daughter took my tablet today to "color" on it at daycare so I won't be trying to flash a boot image. I found an adb driver elektrik posted a while ago and tried EZ Splash Flasher (http://forum.xda-developers.com/showthread.php?t=956434) but that doesn't work. I'd like to work on this more another day but if someone is feeling daring I'd love to see this work and below is an image I designed from some android images on the web if you'd like to use it.
                  Polaroid PMID701C ADB Driver:
                    BTW Drywall-if you (or anyone else) has an interest in having me create a ROM for you with the custom splash animations (until I can create a guide in all my copious spare time lol), let me know-it should be fairly easy for me to do.
                      Hey electric, I think I made the rle from drywall's image...
                      here it is:
                        here it is:
                        http://jtintle.com/downloads/initlogo.rle
                        Cool deal! I'll try to play with adding it Monday. in the kitchen the same .rle file is in .bmp format so *hopefully* it shouldn't be necessary to save in rle format but I have yet to test that theory....
