Currently, I have the Pipo M6Pro, running stock ROM 4.2.2 (20140318). I would like to upgrade to the stock Kitkat. I found the ROM @ http://www.mediafire.com/download/je...4_20140220.rar. However, there is no instruction on it. Doesn't anyone know where I can find the upgrade instruction?
Yes, you will need to flash the new loader. You need to use the RKBatchTool to flash the stock firmware.
I would highly recommend the latest custom ROM we have for this tablet. Our Freaktab developers have redone the complete firmware from Pipo sources and fixed the remainder of bugs leftover in the final stock ROM.
There is a full set of flashing instructions in the zip file for the rooted version....it's good for both versions.
Randy Freaktab Developer, Product Reviewer, Moderator and "Flashaholic". Read my BIO Here
Be sure to donate to support Freaktab.com. If any of my development work makes a positive difference for you, please make a donation to support future RileyROM's. Donate here
Yes, you will need to flash the new loader. You need to use the RKBatchTool to flash the stock firmware. I would highly recommend the latest custom ROM we have for this tablet. Our Freaktab developers have redone the complete firmware from Pipo sources and fixed the remainder of bugs leftover in the final stock ROM. Here is the unrooted stock version: http://www.freak-tab.de/maakie/PipoM6Pro_ROM_141117.zip Here is the rooted version: http://www.freak-tab.de/rrileypm/Pip...tabROM_1.1.zip There is a full set of flashing instructions in the zip file for the rooted version....it's good for both versions.
Thanks. Where can I find the description (fixes & changes) to these ROM? I will try them if the stock ROM doesn't satisfy my expectation.
You MUST flash the new loader.bin to upgrade to KK. Otherwise it will brick your tablet. If you flash the stock ROM with the batch tool...the loader will be flashed.
Sent from my P93G
