I have a PMID4311 with ST's updated ICS ROM that I'm trying to upgrade using Bill Kleiman's latest batch of files. When my attempts failed using CWM 5.5.04 (KKRomKit9), I switched to the CWM 6.0.1.2 that Bill posted.
In both cases, I get this when I try to install any ICS or JB ROM:
Finding update package...
Opening update package...
E:Can't open /sdcard/CyanBook_v0.4.zip
(bad)
Installation aborted
As a test, I also tried to install the compatibility zip for the 4311 but it produced the same error.
Under CWM 5.5, if I tried to start over from the beginning, I'd get this when I reran ROM_WIPER.zip (even though it worked the first time):
Installing update...
E:Can't copy META-INF/com/google/android/update-binary
Installation aborted.
Initially, I thought I might have file/filesystem corruption so I reformated my SD card, redownloaded all files, then ran chkdsk on both source and destination volumes - nope, no errors, no difference.
So, is this operator error, or am I stuck with a vendor-supplied ROM that actually includes WinCE icons in its boot partition? Any help will be appreciated.
Tnx,
DoPa
