Bricked R89 device SOLVED !!!!!!
Originally posted by mauriale View PostUnfortunately it doesn't work for meany other solution? at the i can pass the "Prepare IDB Fail"
please try it with AndroidTool 2.35 (secondTab)(eraseFlash) and try again , this shall solve your problem , hopefully .
please report
nice Day
gefattern
I used to have this issue and it turned out that if I used a USB 3 port, it would always generate and error.
Switching to USB 2 worked, although it took a couple of attempts of erasing in bootloader mode before it worked correctly.
Were you able to get into the maskrom mode by shorting the two holes????
With the AndroidTool and RKBatch I reach to enter in Maskmode, but when I try to Restore or Upgrade it says "Prepare IDB Fail"
Hi mauriale ,
please report
nice Day
gefattern
Originally posted by bluesmanuk View PostI used to have this issue and it turned out that if I used a USB 3 port, it would always generate and error.
Hi to mauriale & all others ,
of course it must be a USB2 otherwise it can not flash the Rom to Box .
Here is a RK flashing Guide :
http://ugoos.net/blog/rockchip-firmw...flashing-guide
If Drivers installed and Rom loaded to AT2.35 , press Recovery Button ,
connect Device to PC , connect Power , if connected In "Loader Mode"
leave Recovery/Reset Button ; press "eraseFlash" wait till ready , press
"upgrade" and wait till finished , wait 5 minutes and disconnect the Box .
Loader Mode not MaskRomMode for this .
good luck
gefattern
good luck
gefattern
There are currently 3849 users online. 0 members and 3849 guests.
