TWRP cs918s
    TWRP cs918s
    This is long overdue.
    I have compile TWRP for the cs918s. I have tested this lightly and from by test's all functions are working as expected, i have used it on the cs918s 5MP 16GB rom device, the a31s one.
    Please report back any thing that you find wrong, add a log and what was the error don't simply said that this or that doesn't work.
    Install method
    - Download the TWRP_CS918S_5MP.zip file and place it on internal SD, reboot to recovery and flash the zip. Reboot to system and next reboot to recovery will be to TWRP.
    v.2.7.1
    www.freak-tab.de/abdul_pt/Allwinner/TWRP_CS918S_5MP.zip
    v.2.8.1
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
    I own you guy's this.
    Tapatalked
      Working
      Hey Abdul_pt thanks for the TWRP.
      It worked fine for me, i backed up to sd card, and flashed an update through it.
      I saw the following while it is loading:
      E:Find_File: Error opening
      '/sys/class/backlight'
      '/sys/class/leds/Lcd_backlight'
      Something i need to do?
      Thanks again
        Thanks.
        Tv box's don't have lcd, so nothing is wrong.
          help needed
          Hi pal, tried it on the newer version CS918s, installed fine but when I try to do a backup it only lets me back-up to internal space and it shows me to have 150mb space.
            Normal.
            Newer CS918s ships with KitKat, and so with SElinux enable. This image uses a 4.2 kernel without SElinux support, not to mention that there should be different partition(s) in KK.
            You are running KK right ?
              Originally posted by Taajan
              Now only if we can get true 1080p.
              I get 1080p on my monitor, but it looks like it can't handle it. I get a lot of blinking pixels and with wrong colors.
              Did you managed to get any source code ?
                Originally posted by abdul_pt View Post
                Normal.
                yes the new boxes come with 4.4 and full 1080p60
                  Do you a link to your FW ?
                  Tapatalked
                    Tapatalked
                    this firmware will install on your box, but no wifi, Bluetooth or camera works, 1080p60 does and the network works
                      Thanks. I will make you a new TWRP and look at this FW for my box
                        http://pan.baidu.com/s/1qWLSW0k#path....2Firmwaresoft
                        Try this image. Flash it from stock recovery or TWRP.
                        If something is wrong provide recovery.log. From advance menu copy log to SD or adb pull tmp/recovery.log or adb pull cache/recovery/last.log
                        Also the output of 'ls -l -R' from '/dev/block'
                          Lol, i would switch to the new firmware however it slows down our box. I use lan on mine so using wireless wouldn't make a difference for me. Also dont use bt
                          Didn't quite understand your point. So the 4.2.2 FW is better than the 4.4.2 image, even if it were fully working ?
                            www..freak-tab.de/abdul_pt/Allwinner/TWRP_CS918S_KK.zip
                            it won't download
                              Had an extra '.'
                              It's fixed
                              Tapatalked
