installed twrp, many errors backed up log but when I reboot the box it just keeps going into twrp
TWRP cs918s
Originally posted by abdul_pt View PostAdb reboot ?
I need the things I asked to check it.
Tapatalked
I am stuck in twrp the pc can't see the box
I have installed your first twrp and that gives me 150mb space but i can't get the files to copyLast edited by whatabody; 05 December 2014, 14:35.
broken
Abdul, I have tried what you said and this is where I am up to.
1) loaded TWRP and made the backup
2) tried to send the DEV/BLOCK folder to my usb drive from ES file explorer it gets to about 3gig and then says failed to copy.
3) tried to compress it and that fails after 2 gig
4) tried to explore the box from my pc but it won't show me the partition where the DEV folder is.
I don't know of any way of getting you the log.
Originally posted by abdul_pt View PostBoot to android.
Open terminal emulator or do adb shell
cd dev/block
ls -l -R > sdcard/block.txt
On your internal SD should be a file named block.txt sent it to me.
That image that you linked doesn't boot on my box.
Tapatalked
I have tried to create block.txt using terminal emulator andadb shell but have issues.
I get as far as creating the file but it is 0 bytes withno data in it when trying to open with a text reader.
When I tried ADB SHELL and the below command it has anerror
When I typed “ls-l -R > sdcard/block.txt”
I get ls: Unknown option '-I'. Aborting.
If I type ls> data/block.txt I get a 0 bytes file in the data folder
Can you please advise?
Originally posted by abdul_pt View Postls<space>-l<space>-R > /sdcard/blocks.text
Confirm that exist a sdcard folder on root.
Tapatalked
they released 4.4 that worked on the 4.2 box . they then removed it a few days later I will upload it to MEGA https://mega.co.nz/#!U4Z1SIJR!rY1ehb...2ZRfIS_UqFKGj4Last edited by whatabody; 06 December 2014, 17:41.
Originally posted by whatabody View Posthttp://pan.baidu.com/s/1qWLSW0k#path....2Firmwaresoft
this firmware will install on your box, but no wifi, Bluetooth or camera works, 1080p60 does and the network works
There are currently 2197 users online. 2 members and 2195 guests.
