does the Neo A2 remote FF/RR button works after updating to firmware 002? can anyone please confirm before i order one.
Neo A2 remote with new F002
You can still buy the Mele F10 Deluxe remote, it has IR learning so you can learn the IR power button code, so you can wake the device up using that. But of course this requires line of sight so it'll be better when the sleep issue is sorted out... But that leaves the possibility to replace other IR remotes (tv, avr, cable stb...)
There are currently 2424 users online. 2 members and 2422 guests.
