Running Android or Linux from an SD card on a RK3288 device - An easy way to dual boot
    While booting the official UT3 Xubuntu 0.3.1 image from SD card, how do you change the FB resolution? It seems to have been fixed at 1920x1080.
      Hello ! I'm just trying to make bootable SDcard , but stuck with error in the console, just after the command is applied - "permission denied" I have tried to check if i have full permissions - so yes , full write access. I'm running Virtualbox and Lubuntu to make it done. What's wrong ? I'm new to linux , so maybe somebody experienced can make image from rkm firmware , so i can just write it by Direct HDD copy . I'm trying this RKM firmware http://www.mediafire.com/file/8xc8p0...0912_Flash.zip .
      Attaching the Error screenshoot ...Click image for larger version
        please try: "sudo ./create-android-sdcard...."
          Hi ! Thanks for your help , but now it stacks again with another problem - "no command found" ...
          As you can see - there are such a file in the directory , so i'm totally lost ...
          Thanks anyway !
            Hi ,
            maybe Virtualbox is the Problem , i think u must use real Linux ,
            but i am no Pro ,
            greetings / gefattern
              Hi all,
              I would like to bluid a bootable SD card for a rk3288 device.
              When running the script like this
              ./create-android-sdcard radxa_rock_android_kitkat_140909_update.img
              with an image found here:
              there seems to be a missing resources.img and the script ends with this error.
              When unpacking the image manually, there is indeed no resource.img nor boot.img.gz that the script needs.
              What am I missing or overlooking ?
              Tools/rkunpack radxa_rock_android_kitkat_140909_update.img
              VERSION:4.0.2
              unpacking
              00000000-00000065 radxa_rock_android_kitkat_140909_update.img-HEAD 102 bytes
              00000066-0002fb1f radxa_rock_android_kitkat_140909_update.img-BOOT 195258 bytes
              0002fb20-25ab4323 update.img 631785476 bytes
              unpacking update.img
              FIRMWARE_VER:4.4.2
              MACHINE_MODEL:radxa_rock
              MACHINE_ID:007
              MANUFACTURER:RADXA
              unpacking 8 files
              00000800-00000fff package-fileackage-file 538 bytes
              00001000-00030fff bootloader:RK3188Loader(L)_V2.10.bin 195258 bytes
              00031000-000317ff parameterarameter:0x2000@0x0 635 bytes
              00031800-0003d7ff misc:Image/misc.img:0x2000@0x2000 49152 bytes
              0003d800-009657ff boot:Image/boot.img:0x6000@0xa000 9601024 bytes
              00965800-015797ff recovery:Image/recovery.img:0x10000@0x10000 12664832 bytes
              01579800-25a847ff system:Image/system.img:0x180000@0x480000 609267712 bytes
              00000000-ffffffff backup:RESERVED:0x20000@0x20000 0 bytes
              0002fb20-25ab4323 radxa_rock_android_kitkat_140909_update.img-MD5 32 bytes
              unpacked
