Running Android or Linux from an SD card on a RK3288 device - An easy way to dual boot
Originally posted by hueb_s View PostSame for me, but it worked (e.g. with Firefly-Image). Maybe the problem is the single partition-layout in the Wasser image? Tried another parameter file with the Wasser image?
I havent tried that yet to be honest im ok with linux been using it for years just need to get to grips with how all this android booting works and what files are needed. Do you have a link to a working system image for this script so i can see whats going on in one that works and try find out why this one isint. Id like to try new releases on sdcard before flashing to nand i notices this in the parameter file has an @ in it anyone know what that actually does? -@0x00234000(userdata)Last edited by grant2258; 01 January 2015, 20:06.
Originally posted by hueb_s View PostThis means the last partition gets all the remaining space. With the single-partition images this is userdata, else user partition.
Originally posted by grant2258 View Postthe linux is running natively
cat /etc/linuxmint/info
RELEASE=17
CODENAME=qiana
EDITION="Cinnamon 64-bit"
DESCRIPTION="Linux Mint 17 Qiana"
DESKTOP=Gnome
TOOLKIT=GTK
NEW_FEATURES_URL=http://www.linuxmint.com/rel_qiana_cinnamon_whatsnew.php
RELEASE_NOTES_URL=http://www.linuxmint.com/rel_qiana_cinnamon.php
USER_GUIDE_URL=http://www.linuxmint.com/documentation.php
GRUB_TITLE=Linux Mint 17 Cinnamon 64-bit
I have installed the boot loader on the box. I did initially have to install sgdisk like i said. All i get is a boot screen and then it hangs.
ive not really been through all how this works i think ill need to look into what the sctripts are doing more to work out what the mattery my side. All i know is when i mout all the partitons as ext4 the only one that has any data listed on it is sdd3 the system partition
If you have problems installing 'ia32-libs' then you will need to use a 64-bit version of 'mkkrnlimg' which is available here https://github.com/phjanderson/Kernel-3188. To download and install this 64-bit version, first change directory to 'Tools' and in a terminal window enter 'mv mkkrnlimg mkkrnlimg.x86' and then 'wget https://github.com/phjanderson/Kerne...ster/mkkrnlimg' and finally 'chmod 755 mkkrnlimg' (note: I cannot stop hypertexting on the 'wget' command so make sure the full path is 'github.com/phjanderson/Kernel-3188/raw/master/mkkrnlimg').
Next please can you run the script 'create-android-sdcard' using the stock ROM for your device? Lets confirm that your SD card build environment is correct and that you can successfully boot the stock ROM from SD card.
Once everything works, alternative ROMs can be tried, including the Wasser ROMs which specifically require the 'create-android-sdcard-no-user-partition' script.
For some reason I got a problem while decoding the boot.img of some ROMs. I tried to manually run split_bootimg.pl on a boot.img of the HPH 1.4 Rom (by mo123) or the finless 1.2 Rom. These Roms are already split in several images (boot, system, kernel, resource etc.) For some reason the boot.img doesn't contain an ANDROID_MAGIC header, so split_bootimage.pl cannot split them. Is there another way to get the ramdisk out of such a boot.img?Last edited by hueb_s; 02 January 2015, 08:29.
Originally posted by hueb_s View PostFor some reason I got a problem while decoding the boot.img of some ROMs. I tried to manually run split_bootimg.pl on a boot.img of the HPH 1.4 Rom (by mo123) or the finless 1.2 Rom. These Roms are already split in several images (boot, system, kernel, resource etc.) For some reason the boot.img doesn't contain an ANDROID_MAGIC header, so split_bootimage.pl cannot split them. Is there another way to get the ramdisk out of such a boot.img?
Originally posted by linuxium View PostAs you are running Linux on a 64-bit environment please make sure you have 'ia32-libs' installed. This is because 'mkkrnlimg' is provided as a 32-bit binary from Rockchip hence the need for 'ia32-libs' if on 64-bit.
Originally posted by hueb_s View PostThe wasser image is a single partition layout. It needs a bit tweaking of the script to work (no user partition).
http://www.freaktab.com/showthread.p...l=1#post255990).
This version of the script handles an Android build which uses a single 'Data' partition for everything rather than having an extra 'User' partition.
Now i have a strange issue with my experimenting the firefly isint booting anymore. Im going to dd the sdcard clear ( dd if=/dev/zero of=/dev/sdd) and try again. Sometimes the bootscreen appears and other times it just doesnt boot at all. I did try with the 64 bit version gdisk is installed as well as ia32-libs. Ill do a full bash script with set -wvf and post a log if dd doesnt work
Originally posted by grant2258 View PostNow i have a strange issue with my experimenting the firefly isint booting anymore. Im going to dd the sdcard clear ( dd if=/dev/zero of=/dev/sdd) and try again. Sometimes the bootscreen appears and other times it just doesnt boot at all. I did try with the 64 bit version gdisk is installed as well as ia32-libs. Ill do a full bash script with set -wvf and post a log if dd doesnt work
Originally posted by linuxium View PostThat is why I wrote the script 'create-android-sdcard-no-user-partition' specifically for the "Wasser" type ROM (see
Originally posted by linuxium View PostI must have missed it so what is your device and what ROMs and/or Linux systems are you interested in running from SD card?
Is just stuck at the firefly boot screen now
Originally posted by grant2258 View PostWell I know the firefly should boot it was yesterday. I did edit the script in a few places not sure what i changed but i deleted it all and extracted your you archive to do this freshly installed. now nothing is booting. I have a tronsmart r28 orion. I want the wasser 2.0.3 roms on my box. But ill stick to firefly because i know that will boot and should work for everything accept sound for testing. Ill add the output.txt file here for you too see. If theres any other info youd like just let me know. attachment is here <- [ATTACH]9581[/ATTACH] ->
Additionally there are two hardware versions on the Tronsmart R28 Orion (PCBA V2.0 and PCBA V3.0) and two versions of Firefly's Android software (v0809 Beta and v0930).
I suggested you start with the stock ROM for your device.
As it is, you have tried a different ROM with an edited script.
Not really the best way to diagnose why "nothing is booting".
There are currently 2506 users online. 1 members and 2505 guests.
