M8 V0.92 Running Extremely Hot
Hi Guys, a few of my friends including me are running Finless 1.8 with the 1008 CPU patch, these boxes get so hot that after about 30mins they just drop the video output...the blue light remains on but nobody is home. I have removed the heatsink and applied some heat paste thinking it may help but it has made no difference. Its gotta be heat related because when it fails I can spray the the board with antifiz and then it powers up instantly. Is there a fix or is it dud hardware? hope its not the latter as there is about 6 boxes behaving the same.
ThanksTags: None
Originally posted by Crows View PostHi Guys, a few of my friends including me are running Finless 1.8 with the 1008 CPU patch, these boxes get so hot that after about 30mins they just drop the video output...the blue light remains on but nobody is home. I have removed the heatsink and applied some heat paste thinking it may help but it has made no difference. Its gotta be heat related because when it fails I can spray the the board with antifiz and then it powers up instantly. Is there a fix or is it dud hardware? hope its not the latter as there is about 6 boxes behaving the same.
ThanksBugs are Sons of Glitches!
JustMe
if still playing up on stock, then collect all your customers boxes and send them back to the supplierBugs are Sons of Glitches!
JustMe
its probably not the answer you wanted to hear but they should not overheat and drop out like that on stock, you probably did damage in first place at 1008Bugs are Sons of Glitches!
JustMe
There are currently 2367 users online. 0 members and 2367 guests.
