I really don't know why the heck I spent so much time on this but enough of you folks were really upset about this feature so I figured it was worth it.
So if this helps you out please consider a donation... Thanks!
This patches the system to make a USB (RF dongle type) Remote Control power the Minix X8 back up using a power button. It no longer deep sleeps!
I ONLY tested this with my Logitech K400 as that is all I have that is USB based that I could test with. But I am pretty sure this will solve any USB remote.
BUT realize if you use USB hard disks they may not spin down with this patch!!!
You get the trade off back that Minix made
NOTE: This only works on my Finless 2.0 ROM for the Minix X8 and X8-H.
If you use this on any other ROM you will not be able to boot!
_____________________________
DO NOT just put this download on the SDcard! Unzip the download and see the readme instructions!
Here are the download links.
PATCH -> Minix X8 USB Remote Control Fix for Finless ROM 2.0 - (9 megs)
Enjoy,
