Cs918 v2_6 20140929 looking for stock rom please help
Or take this --> www.lohadecor.com/Firmware/update-CS918-4.4.zip
This is Android 4.4 for this Box.
Neomode
Originally posted by neomode View PostOr take this --> www.lohadecor.com/Firmware/update-CS918-4.4.zip
Neomode
many thanks for reply but I tried this rom its boot, show logo then screen goes dark and got rebooted again and again . One thing more I find out that when device boot the power light remain red. I tried some of other roms with some of rom the power light goes blue and device stay stable but show nothing on screen. I really appreciate all of ur help . Please if u take a look on this boards pics might be u find the rom. Thanks.
Originally posted by dlangejc View Post
I try to download this rom several times but it stuck in middle all the times.
I have the same board/tv box
Neomode
I'm new to Android TV, Flashing, rooting, custom roms etc, but NOT new to Android as I have rooted many phones and personally use a Sony Xperia Z1 with Cyanogen Mod at present and CWM recovery etc
I've got the exact same device and board I have photos but are the same as this one isted, have tried this stock firmware for this device and it does not work, it just loads up the 'Android' logo that is on top of it, that it originally did load, but then it shuts down again, the button also stays red and does not turn blue.
IF anyone has any more firmwares the first firmware posted as well the screen shows the 3 Linux Penguin logos and then just freezes and does nothing else again, no blue light etc on the box.
Please can people help? Any more firmware ideas would be great, and any custom firmwares.
Thanks for your help if you can.
Hi
I get the same results. I have exactly the same box if anyone could help us that would be great?
Originally posted by Skelmy View PostBump.
Has anyone got any ideas at all, this is quite a widely available Android TV box with loads for sell all over the net.
Please help?
its a backup of that box from some guy on a russian android forum. Hope that helps!
Cheers,
Vec
Originally posted by veclinux View PostTry this link.................https://yadi.sk/d/vCmeb5u3dGW3X
Cheers,
Vec
You're an absolute star thank you ever so much. I was just looking through Chinese listings that can't be translated in the HOPE of finding one that works.
Thanks!! I will try it out.
Originally posted by Skelmy View PostYou're an absolute star thank you ever so much. I was just looking through Chinese listings that can't be translated in the HOPE of finding one that works.
Unfortunately rk batchtool doesnt see it as a valid firmware eitehr the system.img or backup.img I don't know what tools to use to do this.
Can you help point me in the right direction?
I don't understand why people can post something like this (I mean the guy at the russion forum)...
You have to use another tool instead of rkbatch BUT you also have to set it up...
You have to look at the 'parameter' because of the addresses you have to use at RKAndroidTools... to understand it a little bit better, you should have a look at
and also at
"The second way to flash using Windows is the RKAndroidTool witch you can find ..."RK3288 Devices
- Overview BOX (LINK !)
Originally posted by neomode View PostHave found a different Rom that seems to be Working. Post the link later here.
Neomode
To see if I could make it work with that.
I hope to try the one you have found soon.
Cheers,
Vec
ALL we need is the boot image to proceed in making a rom for this device if ANYONE knows of anyone who has this device please PLEASE get them to dump it and upload the results so we can make a firmware for this device as people are CRYING OUT for this and seems the manufacturer is, LESS than helpful by NOT putting this online.
p.s. Neomode says he has tested one and it works PLEASE share it with us? PLEASE
There are currently 2505 users online. 0 members and 2505 guests.
