OTA;
For this release there will be NO OTA, sorry guys..
There are some changes wich can not be updated through OTA
It is technicaly imposible to do.
We decided that it was best to do it now then in a later state as we have to do it eventualy.
Flashable Image:
This firmware will be provided as flashable firmware.
You NEED to flash it with the usb flashtool provided in the download link.
The future of CE;
This will probably last "Community edition" and next releases will become "Official MINIX" releases. This meens it will have the MINIX logo's etc but still our team will be working on it.
After this release and the feedback from it we will also start porting to the X7mini, X5 and X5mini but this will take some time before they are ready. Stay tuned
Changelog (2.1.0)
- sleep suspend fixed( wakeup from USB Remotes / IR remote / Powerbutton )
- fully renewed audio bitstream system + audio input fix ( show usb audio input devices )
- Screen settings all on one page
- aditional VPN/networking config ( IPIP,L2TP,PPP )
- removed PIN for VPN settings
- VPN wifi hotspot fix
- Removed google searchbar from desktop
- long press menukey to hide/unhide systembar
- update drivers for future X5 branch
- recovery show UI + Null pointer fix
- USB storrage announcements framework renewed
- wifidisplay / miracast HDCP key integration ( not functional yet )
- libffmpeg and RKffplayer updated to version 8-12
- fixed RKexplore app
- fixed WifiDisplay app
- Small HLS fix ( not much yet )
- Updated Gapps ( Google Apps )
- Google sync issues fixed
- New kernel logo / bootanimation ( add KAR )
- a few others
Old Changelog (2.0.0);
- recovery/OTA fix
- static ip bug fix
- video player/hls fixes
- security vulnarability fixes
- init.d support
- camera brightness fix
- freeze after uninstall app fix
- HDMI patch for DRM apps
- DDR optimalisation ( not overclock )
- Multi user support ( not fully working yet )
- Dual input devices frees/crash fix.
- new kernel logo
- etc.
Download link:
(NOTE this is version "b" with bluetooth fix)
If you allready installed the first version of CE 2.1.0 please download the fix under "Available Updates".
http://www.minixforum.com/downloads/...CE_v2-1-0b.rar
WARNING!! WARNING!! WARNING!! NOT EASY TO GO BACK TO 4.2!!
(You need to use RK flashtool, do not try to flash it like an OTA update.zip !)
Available Updates:
X7 CE v2.1.0 - root update
X7 CE v2.1.0 - unroot update
X7 CE v2.1.0a - bluetoothfix
To install the available updates (this is not for the Firmware!) rename the downloaded file to update.zip and place at the internal flash drive root or USB stick root, android will find the update and request you to install.
From the MINIX Forum Developers Team;
@gufone
@KAR
@HardwareGuru
