After a reboot, the prompt to update pops up almost immediately.
MINIX X7 KitKat 4.4.2 CE ( Community Edition 2.1.0 )
Originally posted by HardwareGuru View PostIt does recognice.. Reboot is not needed.. Just copy the update.zip to internal flash or copy it to an usb stick and put it in your x7.. Then just wait till the popup comes to install the update.
Originally posted by Speedster View PostI still have problems regarding DD & DTS sound.
No matter what I choose as soundmanager, I only get PCM instead of DD or DTS.
Of course in XBMC passthrough is selected in audio options and DD DTS capabel receiver is activated.
Is this a known problem?
- Test your clips with the standard RockChip Video Player
- Check your receiver if there's an option to switch between PCM and Bitstream (or if you have Stereo mode enabled)
I will try to re-install the rom and start from scratch.
My Harman Kardon receiver switches automatically between PCM and DD. I have HDMI connected and also spdif is possible.
HardwareGuru's previous rom (based on 4.2) worked great.
I will report the result of course.
OK, re-installed everything and now all is working great!
Originally posted by ivbsd1 View PostTried, did not work
Originally posted by dsa13dsa View Posttry this CWM: https://yadi.sk/d/TQi96rEDd9Qay
There are currently 1455 users online. 1 members and 1454 guests.
