I will flash it tomorrow and give news.
MK808 Android mini TV Player - Finless ROM 1.5 Custom ROM
Originally posted by Javimetal View PostBob, can you tell me how do you unpack the .img files? I don't mean the boot.img, system.img.... I mean when you download a firmware or update like update_mk808_box.img HOW can unpack this .img file??? THANKS!!!Android TV Box direct from China. English & EspaƱol
can`t flash rom
When i use ROMFlashTool.exe detect the device but when i try to reboot to flash mode ; got error () but fount device rkandroid.... is correct.
i can update the firmware with Rockchip_Batch_Tool_v1.5.exe i use the procedure in : http://blog.geekbuying.com/index.php...te-on-3th-nov/.
do i need to transit to another file to get access with flashrom ..
thanks
help me please!
Is this for MK802 II version? I purchased here: http://www.****.com/itm/230845229135
Can anyone provide me some guidance to flashing latest Android stable ROM (of Finless?) and also installing Linaro and/or Ubuntu via SD card?
I appreciate all the help!
sound
hi i insalled this on my mk806 (with the same intenerals as the mk808) but it has a built in 3.5 headphone jack. everything is working on this rom except for the headphone jeck. is their anyway to fix this it is not showing up in the sound manager in settings, do i need to buy another sound card is their an app or drivers that i need to install. if i need to buy a sound card which one should i get? and also i have looked all over but i have yet to find a place to download the og firmware for the mk806.
There are currently 2537 users online. 1 members and 2536 guests.
