ROM 支持中文吗?ROM support Chinese?不知道我的英文对不对。
MK808 Android mini TV Player - Finless ROM 1.5 Custom ROM
There is something wrong on the last release !
The HD video files on Youtube are stuttering while playing. I tried with wireless and ethernet both. Same problem.
There was no any problem with the previous firmware... One problem is finished , next one is started(
We will not have a good stable firmware for MK808 I thing...
Regards
My 1.5a ROM is almost ready based on 10/27 release. I will start a new post for it.
This thread is 1.5 and is based on BETA 10/26. My new 1.5A (see the sticky thread) is based on BETA 10/27 which is the ROM your talking about that deadhp1 used.
CPU
Does someone knows how to solve the cpu speed problem?? It is unsane, it works as it was set 1ghz/1ghz or on the performace governor, it stays always on 1ghz, that was on stock, I am tryng this ROM because I thought that with root i coud control the cpu... but nothing... I even tried the 1.4v... this is crazy because it heats up and will live less... not inportant to go further than 1ghz, but it should scale down, when playng a video 240mhz is all you need...
thanks
Bob,
can you tell me how do you unpack the .img files? I don't mean the boot.img, system.img.... I mean when you download a firmware or update like update_mk808_box.img HOW can unpack this .img file???
THANKS!!!Android TV Box direct from China. English & Español
OK log out.
Then at the top of the web site login there and check the box, keep me logged in.
Should work then.
There are currently 1940 users online. 0 members and 1940 guests.
