MK808 Android mini TV Player - Finless ROM 1.5 Custom ROM
Originally posted by jefflessard View PostThank you Finless for your great work!
I updated to ROM 1.5 yesterday and I constantly have problem with the WiFi. Sometimes it shows as connected but apps can't reach the network. Sometimes it shows as not connected, but WIFi Analyzer shows about -50db signal which is good.
Is anybody else suffering the same? How do you get around it?
Personnaly, I either wait a couple of minutes or I power down the unit... but I would like a software fix if possible.
By the way, it really seams like a software issue, does anybody knows how to get hands on the kernel source code?
Still some WiFi issues
Bob,
thanks for the new ROM. I've installed it and played for two days on a Samsung 32" HDTV via HDMI.
Resolution is OK, Antuntu gives me a 6986, where with your previous ROM I got around 6400
Youtube is not working, and I had to uninstall the version and install a previous one I have in an apk Youtube V3.5
Wifi is strangely working as follows: It connects and working in 65MBps but a lot of times it gets disconnecting and reconnecting either in YouTube in-between two different videos (at the end of one video I press to load another one, the WiFi disconnects and then reconnects and then the video starts to download) or in Google Play. But when it starts downloading a YouTube video it does not disconnect. Or when it downloads an app it does not disconnects.
Or when I listen to tuneit it does not disconnects.
I have a wireless keyboard connected via a USB Hub dongle.
Also the camera does not work with FXCamera Free. With Finless ROM 1.4 it worked OK.
But now with the new option in Settings->Sound the camera's build in mic is working in Skype.
I have a Microsoft VX-800 connected via USB Hub.
In any case I find that new ROM overall better in terms of WiFi stability, but I suppose something is missing yet.
Thank you
Originally posted by Finless View PostHello again folks!
I am back with a new ROM for the MK808.
This was made using the latest Jellybean ROM for the MK808 released 10/26 (today) by the manufcaturer!
I'm thinking about buying mk808.
I'm really confused because i read reviews and i watched on youtube some videos and it seems it could be a great product, but i read some forums with some negative impressions about wifi and other problems.
So, what's the true? why for someone works and for someone not?
Networking Alternative
Hi Bob,
Just like many others I wanted to say a HUGE thanks for your ROM.
Whilst it may defeat the purpose a little I hooked up an ASIX AX88178 USB Gigabit Adapter via the OTG port using a mini hub and it's been really stable. I haven't done any benchmark tests yet but it's been really solid. I bought mine at Amazon for around $26 and got free shipping via Prime, anyway here is the link if anyone is interested http://www.amazon.com/gp/product/B00...ls_o05_s00_i01
One thing I'm finding is that Apps I'm loading onto the MK808 are disappearing after some reboots ... can't figure out why since I thought the RAM was persistent but maybe not. I would like to get XBMC to stick around with config options ... that would be awesome !
My dream is to get Linux up and running on this bad boy ... but based on the lack of source I'm wondering if that's ever going to be possible.
A greek can dream I guess
Originally posted by alberto View Postboys but if I connect a usb ethernet device is detected? .... otherwise what's the ethernet option?
Something like this: http://www.****.com/itm/White-USB-2-...item2a250500d6
Thanks Bob for this excellent Rom.
Comparing to the rooted ICS rom, this one is snappier, but wifi is worst. I use ipad 10w power supply and wifi never dropped to 5Mbps under ICS. Though ICS has very annoying video/audio sync issue which never be an issue with JB!
I now give up the internal wifi and been using a usb wifi with great and stable performance.
One issue is from time to time, I can't open some apps, e.g. Facebook and the email client; it opens up a short while and close itself. Reboot seems to get them back.
Originally posted by Finless View PostMy firmware is based off this firmware. Why do you think otherwise?
Stuck at the Boot Logo if I remove the power - do Someone have a CLUE?
Dear All
It happened to me already 3-4 times (1 with the stock new firmware).
After performing a bunch of installation from Google Play, I powered off
(hard-way, removing the power connector from the +- plug).
Then when I reboot the mk808 remains stuck at the boot log. (and Then I re-flash)
About the rest the room is fastastic, i would like to report also 1300 points in geekbench which makes this things faster than the new Ipad and slightly slower than with Galaxy SIII, I phone 5, and other last generation phone, tablets. I can report that my Tegra3 Asus infinity score 1650 on geekbench (stock jelly bean).
Trycage
Trycage
WARNING! If you read nothing else READ THIS!
On this kernel the reboot APP is causing Cache or file system corruption! This is not the reboot APPS fault. This is intermittent. Sometimes it works OK sometimes not.
The kernel is NOT properly processing the reboot command and is corrupting file systems!
SO DO NOT USE REBOOT from the reboot APP! YOU HAVE BEEN WARNED!
All other functions seem to be OK except reboot.
In fact the unit WILL power off believe it or not using the power off command!
If you use reboot and are stuck on the boot screen or boot logo, you will have to reflash the ROM.
We will work on seeing if we can fix that later but I believe it is a kernel problem.
The other kernels do not have this problem.
Originally posted by BooLE View PostFrom the first post in this thread. I had the same problem and reflash is by far only solution. But it is not only reboot application, it is also pressing ctrl+alt+del on my flymouse keyb.
On this kernel the reboot APP is causing Cache or file system corruption! This is not the reboot APPS fault. This is intermittent. Sometimes it works OK soYmetimes not.
Yes I read the first post,
But it happened to me so many times that I was wondering How can I shut down without corrupting. Does The shutdown (reboot) soft button help?
There are currently 1847 users online. 0 members and 1847 guests.
