MK808 Android mini TV Player - Finless ROM 1.5 Custom ROM
Originally posted by Krinyo View PostCPU clock still locked to 1008 Mhz, not a simple energy management. Still bunch of crap. The very first firmware had 12xx MHz clock...
However many of us running that speed had heat problems! Which is probably why they dropped it to 1008.
old kernel remains 1024*768, right?
I can not flash mine anymore. nand flash is dieing
Originally posted by Finless View PostIf you flash with the provided older kernel you will have 12xx. It is in the ROM kit and you have a choice.
Yes the older kernels will have the 672 resolution.
Nand dieing? Wow I have flashed probably 100 times now and no issues. Nand chips are rated for over 10,000 flashes!
This thing have many venting holes, heatsinks, so what is the problem with 1,6 GHz CPU clock??? set it to on-demand, and most of the time it will run at 2xx MHz! This thing advertised as a revised, improved product over UG802, and it's not. Possibly somebody not able to compile a GOOD kernel for it.
It's false advertising, I buy MK808 for promises (more memory, heatsink -> faster CPU, new WiFi, dual antennas, etc.) and there is a whole crap for the money.
Older kernel: wrong screen ratio, no go.
This new firmware is unstable, I have FC a lot.
Bob!
There is some problem with the governors, or related settings. With SetCPU I was able to "overclock" the CPU up to 1416 Mhz. This led to spin the thing 55 Mflops multithread performace to over 90 Mflops! Antutu score went to 7328!!! The whole system much snappier now.
On demand, and other governor settings simply not working, the system not scaling dinamically, and if, stopping at 1008 Mhz. Can we fix this somehow?
Bob, can you make a clean ROM? Because there are also many people that use this kind of mini pc just for some basic functions like browsing, playing youtube videos, chating or playing simple games and maybe they don't know how to remove the unwanted and unnecessary apps. Would be very nice if you could remove all the chinesse apps (wich, by the way, have chinesse menus and nobody understands them) and post a simple and clean ROM. I belive that you do this allready for having a clean starting point before adding the "pro" apps and funtions.
So, if you can, please post two versions of each ROM revision (a clean one and a "PRO" one).
Also, a SOFT SHUTDOWN working button will be great! Also, rising the apps storage space from 1,5 to 2GB it's a very good decision!
I really apreciate your work!
Thanks!
Cristian, am I missing something here?
Did you read the read me or flash this ROM?
I already removed all the junk apps!!!! AND..... I already added a reboot APP etc! It's all in my description! Again am I missing something here or is reading NOT fundamental????
Krinyo, no can do... ALL that stuff is in the kernel... So no way can it be changed without a new kernel.
Novita' mk808
salve a tutti scusate...se non mi sono presentato.Il mio nome e' Dilio e scrivo dall'italia.ho acquistato da poco tv box mk808, dal primo giorno ho avuto problemi con wifi, e mi sono messo a ricercare su internet qualche rom per poter riparare il problema .Ho fleshato tre volte.... 1.con:update_mk808_pad_204j1.img.... 2.con Vostro firmware mk808_finless14_rom(molto buono e bello,migliora di poco wifi).....3.con altro firmware uscito ieri dal costruttore :rooted_jb_update_3(27/10)......ma niente di niente.
Pero' posso dire che il problema wifi...ragazzi e' conflitto di periferica collegata al tv box...ne sono sicuro,se state usando mouse o tastiera con dongle wirelless(questa fa conflitto secondo me, molto vicina al modulo wifi del tv box)allontanare con una prolunga usb e risolvete il problema.Sara apposto il wifi con qualsiasi rom e/o firmware installato su tv box.
Spero che sia vero provate e fatemi sapere....se speranze che ho descritto sono vere....io sto ancora provando spero bene.Per essere completa questa tv box manca cosi' solo swhicth on off poi e' ok!
ciao saluto....scusate per italiano....ma con google traslete oramai non c'e' problema .Bob: CHEERS
Originally posted by alberto View Postsalve a tutti scusate...se non mi sono presentato.Il mio nome e' Dilio e scrivo dall'italia.ho acquistato da poco tv box mk808, dal primo giorno ho avuto problemi con wifi, e mi sono messo a ricercare su internet qualche rom per poter riparare il problema .Ho fleshato tre volte.... 1.con:update_mk808_pad_204j1.img.... 2.con Vostro firmware mk808_finless14_rom(molto buono e bello,migliora di poco wifi).....3.con altro firmware uscito ieri dal costruttore :rooted_jb_update_3(27/10)......ma niente di niente.
Alberto is saying that the Wifi issues are likely due to a usb wireless keyboard\mouse dongle being close to the wifi antenna and maybe we should try connect the the dongle with a usb cable and report back if that fixes it.
Ciao,
Enzo
Ciao alberto visto che sono italiano anche io volevo sapere se per flashare questa rom hai usato lo stesso metodo per flashare quelle originali . Volevo provare questa perche con quelle originali non vanno sul mio tvOriginally posted by alberto View Postsalve a tutti scusate...se non mi sono presentato.Il mio nome e' Dilio e scrivo dall'italia.ho acquistato da poco tv box mk808, dal primo giorno ho avuto problemi con wifi, e mi sono messo a ricercare su internet qualche rom per poter riparare il problema .Ho fleshato tre volte.... 1.con:update_mk808_pad_204j1.img.... 2.con Vostro firmware mk808_finless14_rom(molto buono e bello,migliora di poco wifi).....3.con altro firmware uscito ieri dal costruttore :rooted_jb_update_3(27/10)......ma niente di niente.
There are currently 2555 users online. 1 members and 2554 guests.
