Which is the newest official M8 firmware
Originally posted by userofthenet View PostThank you for the tip but I guess I have had enough testing different firmwares. I am now happily running justme 1.5 with oman xbmc 13.2.
Originally posted by JustMe View Post1. get blank sd card 1gb or higher
2. load burnBootCard format sd and load the uboot.bin file
3 after load the .wps extention file on sd card via windows
4 place sd in device
5. short pins 17&18 of the tsop 48pin chip dot being pin 1 there is pictures posted here on forums
6. have jumper over otg port pins ( view photo)
7. get probex.img file ready from freaktab forums
8 open up usb burn tool & load the probex img file
9. have the reset button pressed while connecting power to the device
10. connect usb cable and wait for windows to reconise the device and for usb burn tool to show up hub it may take upto 1 minute while reset button is still pressed
11. then once reconised force flash
12. keep repeating the process you will get few percentage higher each time
I'm sure some posted on forum a methid could of been on another forum cannopt remember now when i get back home later today I am sure i saved the link could of even been no spam me
There are currently 1766 users online. 10 members and 1756 guests.
