One thing I wish I could have fixed was USB OTG but I wont give up yet. Maybe the next ROM.
So, if you find my work worthy, please feel free to donate.
__________________________________
This ROM comes with no instructions or readme. I will work on that as I do more ROMs.
I just did not have the time to write that all up.
So, this means you need to know what your doing and how to use the Phoenix flash tool and drivers. I don't have time right now to write up better instructions.
Get the tools and instructions fro Geekbuying.
Change log:
Same stuff as my 1.0 ROM
1) Debloated of junk
2) Proper root which doesn't use install recovery script! You wont loose root this way ever.
3) Updated all Google framework, Play Store, and APPs to latest and this includes superuser and SU binary.
4) Added init.d support properly (not using install recovery script).
5) Adjusted some buffer sizes. Let me know if it helps video playback!
6) Added reboot APP
7) Put in KK AOSP launcher and cleaned it up. I like the icon layout better.
8) Adjusted LCD density to 240 so text, icons and things are not so tiny.
9) Spoofing a Samsung Nexus 10 for better Google App Compatibility. Also adjusted fingerprint for release-keys. The original build.prop is in /system if you want to go back. Just rename using ES File explorer.
10) Did a little theming
NEW STUFF in 1.1
1) I adjusted the DDR memory clock speed for video playback. It was set really low for some reason. I did not over clock but I brought up the speed to the same as home screen for running APPs. For me this seems to have really improved video playback skips.
BUT I NEED you picky guys to tell me how it worked for you.
PLEASE WATCH BOX TEMPS! Mine are OK but I did not play a huge amount of movies all the way through! Just keep an eye on it while testing.
2) Fixed live wallpapers and handler
3) Fixed Google calendar and contacts sync. In fact fixed all Google sync issues. However, the Google contacts APP wont work (phone emulation is ripped from the ROM) so find another contacts APP.
4) Added back some missing frameworks needed for some APP compatibility! So you should have more apps showing compatibility.
5) Fixed up some missing permissions and XML files Google looks at. Again should improve APP compatibility.
6) Fixed Location Services. Now Google Earth, Maps, or any other APP needing location services will work. Remember to turn it on as I left it off by default!
7) Camera APP is now fixed and works! I tested it with my Logitec C110.
8) Some other tweaks here and there that I do not fully remember now... Sorry... But here are some.
Added busybox (it was missing), Stock AOSP Email and MS Exchange added, Text to Speech now fixed, fix missing libraries and bad libraries, other stuff I do not remember now...
____________________________________
Download this and unzip it. You will have a .img file. Use the Phoenix Suite flash tool to flash this.
ROM -> Draco AW80 - Finless 1.1 ROM (332 megs)
Enjoy,
