Seems to be a problem because of power (spin-on)...
NEW - Draco AW80 - Finless ROM 1.1 - BETA2
Originally posted by no_spam_for_me View Post
Seems to be a problem because of power (spin-on)...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by Zahir View Post1. Paid apps show up and install fine here
2. No HDMI issues
3. Dolphin 11. from the Play Store installs and runs (on the Fantasy rom it crashed). I don't use Flash, don't know which sites people use and so can't confirm it works.
After running this box continuously for 14 hours, it gets warmer than with the stock rom, but in no way that worries me. H264 video in XBMC and MX Player remains the best of any rom. I suspect improvements in H265 call for new or optimized PowerVR drivers.
Originally posted by no_spam_for_me View PostThe same at stock rom... maybe not enough power at the port... will try an active HUB...
Also when you plugged in. Look what happened. Cache got corrupted! So pretty sure the voltage hit is causing problems.
<6>[ 3.813902] fs_mgr: Running /system/bin/e2fsck on /dev/block/by-name/cache
<4>[ 3.856347] e2fsck->main: e2fsck start...
<4>[ 3.856375] e2fsck->pipe_write: pipe_write type=1
<6>[ 3.874175] e2fsck: e2fsck 1.41.14 (22-Dec-2010)
<6>[ 3.874241] e2fsck: /dev/block/by-name/cache: clean, 12/40960 files, 5257/163840 blocks
<6>[ 3.882217] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,barrier=1
<7>[ 3.882254] SELinux: initialized (dev mmcblk0p15, type ext4), uses xattr
<7>[ 3.893743] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 115181
<7>[ 3.894394] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 115240
<7>[ 3.895259] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 115219
<7>[ 3.895367] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 115208
<7>[ 3.899727] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 114977
<6>[ 3.899829] EXT4-fs (mmcblk0p1): 5 orphan inodes deleted
<6>[ 3.899839] EXT4-fs (mmcblk0p1): recovery complete
<6>[ 3.946533] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
Originally posted by no_spam_for_me View PostOK, with an active HUB (shown as usbhost0 at ES) it works, but it's only an USB2.0 HUB...
- The 'Hitachi HTS545032B9A300 320GB SATA-II 300MBs 5400-Umin 8MB 12ms' works
- The 'HGST Travelstar 7K1000 1TB 2.5 SATA-III' NOT (also at the X8 only with active HUB)
The HGST is recognised as USB6002 (like USB5002 for the WD) BUT the Hitachi as 8_1 (but contains two partions)???
At USB 2.0 the WD works (as usbhost2 at ES ??), the HGST (as USB1004 at ES) NOT and the Hitachi (as 8_1 at ES ??) of cause also works...RK3288 Devices
Originally posted by Finless View PostAlso when you plugged in. ...
But I think that's the moment where the system tries to connect to the HDD...RK3288 Devices
Maybe..... On the S802 early on they increased cache partition size (from 32megs to 64 megs) to support drives 1TB and larger.
Maybe if I increase cache partition it will solve some drive issues.
Later this week we will try.
But my 1TB drive did work but I have 2 partitions.
Needless to say, these drive issues are probably on all ROMs so far!
Originally posted by Finless View PostNeedless to say, these drive issues are probably on all ROMs so far!
Bob)
RK3288 Devices
Originally posted by frhdt007 View PostYou may install Flash player 11.1.115.11 from Archived flash player and test with phim3s.net
1. Dolphin for Android installed from the Play Store, Flash 11.1.115.11 installed, Flash Always On
2. At your (Vietnamese?) video site: all on screen flash animations are active; I was able to play trailers and clips in very good quality. I couldn't get a full-length movie to work(membership required?)Last edited by Zahir; 17 December 2014, 17:29.
Originally posted by no_spam_for_me View PostReally? You aren't able to manage the power at the port? (just kidding)
Originally posted by Zahir View PostOK, I'm pressed for time right now, but this is what I found:
Originally posted by Finless View PostMaybe not understanding? Your drive that did not work I thought you tried powered USB hub?
The 'WD Elements 1TB 2.5' works without an active USB-HUB at an USB 2.0 port at the Draco, BUT not at the USB 3.0 port at the Draco (only with an active USB-HUB (but 2.0 and not 3.0))...
I didn't test the 'HGST Travelstar 7K1000 1TB' at the external 2.5" case with an active USB-HUB (didn't work at both, the 2.0 and the 3.0 (but that wasn't a surprise, because I know from the minix x8 that I need an active USB-HUB (at the USB 2.0)))...
So it must be a power issue at the USB 3.0 port... and I'm wondering (as kidding / just a joke) that you aren't able to fix this problem by manage the power at the USB 3.0 port(of cause you aren't able) ...
RK3288 Devices
finless job ROM 1.1
Hello there. Bob google play store is picking up my paid apps now, must have been when I rebooted the box. The HDMI unplug and plug back in to get sound still needs looking at though. Thanks. PS. That's when you have time Thad is. Thanks.Last edited by bigall123; 18 December 2014, 18:44.
There are currently 2224 users online. 1 members and 2223 guests.
