NEW - Draco AW80 - Finless ROM 1.1 - BETA2
Originally posted by 140hours View Post
Originally posted by 140hours View PostI got the videos to play, but now MX Player Pro is complaining it doesn't do AC3 or DTS sound?
Because, ?maybe I misunderstand it?, this is only for downmix/-size to stereo:
Originally posted by Sarco View PostGo in mxplayer settings/decoder, last entry is for customs codec available in google store, you should be redirect.Originally posted by marphsai49 View Postgo to this link
https://github.com/USBhost/MX_FFmpeg is my modified source where i'm building from You can download recent codecs here ( GitHub releases ) and 1.35.0-1.8.6 here ( Google Drive ). Also the XDA download tab is no longer updated as for some reason I...
download arm v7 neon.
then use this codec in mx player settings/decoder/custom codec
don't unzip the fileRK3288 Devices
- Overview BOX (LINK !)
BTW: I don't need it at stock fw, downmix/-size to stereo works out of the box...T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Ahhh, ok, then I misunderstood it, I thought it was only for downmix/-size to stereo (if the rom doesn't support it) ...
BUT I don't understand all these licence things at path-through, because I thought you get the licences at the AVR, because the AVR is the unit which makes the audio-data-stream usable....RK3288 Devices
Originally posted by no_spam_for_me View PostAhhh, ok, then I misunderstood it, I thought it was only for downmix/-size to stereo (if the rom doesn't support it) ...
BUT I don't understand all these licence things at path-through, because I thought you get the licences at the AVR, because the AVR is the unit which makes the audio-data-stream usable....T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Originally posted by otisrhw View PostWell I give up! Netflix sucks on the a80 tried everything I got but over my head! Jittery picture, status bar unusable! I heard netflix does this on nexus tab as well. I thought might have something to do with auto hide nav bar but guess not.
I can use it and yes watchable but not right! Sorry but I'm not a good enough kind of guy! Actually one of the worst netflix experience yet! This thing should have no problem! For once beautiful deep color and contrast but still missing some things! I'm just venting my frustration, I'll keep at it. It was at this point that I figured out problem with popcorn time hw decoding on droid.
This has nothing to do with this rom Netflix issue happens on a multitude of devices.
Re: NEW - Draco AW80 - Finless ROM 1.1 - BETA2
Hi There,
I have a question if someone can help me:
The mouse cursor seems too high(big). You can change less? how can I do that? Thank You.
Sent from my Draco AW80 using TapatalkTronsmartDracoTelos - Firmware custom: dowless1.9
Ugoos UT3 - Firmware oficial v2.0.4
AT YOUR OWN RISK
You can change the mouse pointer by replacing the pointer arrow PNG file located in Framework. The pointer arrow is located in the /system/framework/framework-res.apk (=> Res/drawable-mdpi/pointer_arrow.PNG). Since it’s an APK you can modify it with 7zip and push the new framework with ADB or use any root explorer...
Code:adb pull /system/framework/framework-res.apk framework-res.apk copy framework-res.apk framework-res.apk.org
Code:adb push framework-res.apk /system/framework/framework-res.apk
RK3288 Devices
There are currently 1849 users online. 0 members and 1849 guests.
